Here's what I would like to do... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2009, 01:41 AM   #1 (permalink)
View ProperElite's Photo Gallery
So I have been working some overtime at work recently so I am going to have a little bit of extra cash and I would like to maybe put some money into my car.
What I REALLY want is to add a genuine Toyota rear spoiler and genuine Toyota Camry side skirts (ground effects).
I found a spoiler here: http://www.toyotapartsstore.com/prod...oducts_id=3078.
It says something about an installation template and was wondering if anybody here had installed a genuine spoiler on a gen 5 Camry.
And for the side skirts, I haven't been able to find a place where I could get them (just aftermarket body kits...I would like to stay with Toyota)
Here is an example of the side skirts: http://carphotos.cardomain.com/ride_...0001_large.jpg
Thanks in advance for the replies.
2006 Toyota Camry LE 2.4L
ProperElite is offline   Reply With Quote
Old 09-14-2009, 01:44 AM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
You get them from Toyota.
Redline_Me is offline   Reply With Quote
Old 09-14-2009, 10:11 AM   #3 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
+1
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 09-14-2009, 11:12 AM   #4 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
the kit is expensive 1000+ from factory =[
i want that kit also.
GL with search, if you fine a good spot let us know!
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 09-14-2009, 02:04 PM   #5 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
A template is required because you need to drill holes to install the spoiler.
My Partial Partout!!!
Photo Album
Old 09-14-2009, 02:07 PM   #6 (permalink)
TNNN, uh?
yuriy's Avatar
View yuriy's Photo Gallery
^ Respect
PROUD MEMBER OF TN // TOYOTANATION.COM
09.14.09
yuriy is offline   Reply With Quote
Old 09-14-2009, 05:31 PM   #7 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
I have, and like Netforcer said, you will need that template to drill the holes in your trunk to install the spoiler.
If I remember correctly, one of those holes is 1" in diameter... when I did my installation I used a hole saw. I would recommend using a step drill bit instead. You get a cleaner and more accurate hole with a step drill bit. I would also recommend using a center punch to mark where the holes should be... otherwise the drill bits will very likely slip.
Triple check the placement of the template... if you drill the holes wrong the spoiler will not look right when installed.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-15-2009, 02:44 AM   #8 (permalink)
I changed my mind...fuck the spoiler. I might just get a lip spoiler.
Old 09-15-2009, 11:23 AM   #9 (permalink)
View Nick :D's Photo Gallery
As for the spoiler, you can get one on Ebay brand new, "OEM styled" (which is in theory the exact same thing). for less than half of the price that website would charge you.
I have the OEM styled spoiler that I ordered from ebay that came painted and with all the accessory parts for $130.
Now for the kit, the only practical way you can get it is if you find a camry with that kit, copy down its vin number, and bring it to Toyota, where they can order you a "Replacement Set". And that would be quite expensive.
I chose to go with the JP Vizage kit. Check it out, and good luck with your camry
FS: Gen 5 Camry Roof Scoop"
Nick :D is offline   Reply With Quote
Old 09-15-2009, 11:28 AM   #10 (permalink)
TNNN, uh?
yuriy's Avatar
^ +1
09.14.09
