2005 Camry code P0778 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2009, 06:40 PM   #1 (permalink)
View DaleD57's Photo Gallery
I have a 2005 Camry XLE V6, 30k miles. I was driving home the check engine, trac off and vsc lights come on. I stopped at AutoZone and they pulled the code, P0778.
Pressure controle solenoid "B" electrical (SSV SL2)
Likely causes:
1 Open or short circuit
2 Low transmission fluid
3 Shift solenoid valve
The fluid is ok. Anyone seen this?
Am I looking at an expensive repair?
DaleD57 is offline   Reply With Quote
Old 09-18-2009, 07:09 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Aisin U-151 5-speed transmission? IMO the entire U-series transmissions are bad news. You just found out.
I'd take it back to the dealer and they should fix it under the powertrain warranty. So if you're the original owner it should be FREE repair.
Likely causes:
Old 09-18-2009, 07:12 PM   #3 (permalink)
I don't know which transmission, the one that comes with an XLE.
I'm the second owner.
What is the length of the powertrain warranty for these cars?
Old 09-18-2009, 07:47 PM   #4 (permalink)
5 years/60K miles. Not sure if it's transferable.
It's a U-series transmission. They have much more problems than the earlier A-series.
Old 09-18-2009, 08:00 PM   #5 (permalink)
Great.
I quit buying Pontiacs because the Bonneville I had would break every few thousand miles.
I have a Toyota now, I put 4000 miles on it in one year, (bought it with 26k miles on it), and the transmission breaks.
I guess I'll have to switch to Honda?
