Parking Brake Adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2009, 03:53 PM   #1 (permalink)
View docfeelgood's Photo Gallery
2002 Toyota Camry LE
Guys, I'm new to this site, so i apologize if this question has been posted in another thread, but I'm short on time and the sun is setting fast.
I just swapped out my existing front rotor and pads, with new, and i swapped out my existing rear shoes with new.
The car rides beautifully, but when I pull the emergency brake my tires don't lock up as I would like, but rather the car will coast to a stop. So the E-brake needs a little tweaking.
This is the last link in my brake upgrade. I have the tires back on right now, but tomorrow morning I'll take a look at it again. My pictures of the rear brake assembly don't show the E-brake cable very clear.
I can't recall if there is a threaded nut on the end of the cable or if its a pressed fitting on the end of the cable.
Also it doesn't have to do with shoe adjusting set screw, right? I was tweaking that assembly over and over, in order to get the drum on snug. The E-brake cable should have a thread that you just move up the cable right?
Any thoughts?
docfeelgood is offline   Reply With Quote
Old 09-19-2009, 04:58 PM   #2 (permalink)
View lenjack's Photo Gallery
Don't know if this will help, but on my '98, the adjustment was in the console, under the shifter.
Any car problem can be fixed with a large enough hammer!
lenjack is offline   Reply With Quote
Old 09-19-2009, 05:38 PM   #3 (permalink)
...Sweet, thanks for PDF, it cleared up a lot for me. A picture is worth a 1,000 words.
So the clearance is right-on accurate.
I never adjusted the E-brake lever within the car, but I'm guessing that if i loosen and then re-tighten the adjust and lock nuts, as shown in the attached picture, that should tighten the entire cable, thus rendering a tighter feel when i pull the lever, correct?
Currently, I have to pull the entire length of the lever. Whatcha think.
Old 09-19-2009, 06:47 PM   #4 (permalink)
thanks buddy, you've been a great help.
I'll let you know how I make out with it.
Old 09-19-2009, 06:49 PM   #5 (permalink)
Gameroom cash: $110800
View '02 XLE V6's Photo Gallery
+1^^
Although I have the foot pedal, the same type of adjustment is what got my E-brake nice and snug after I replaced my rear pads and rotors and got the shoe clearance set.
'02 XLE V6 is offline   Reply With Quote
Old 11-10-2009, 02:10 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
wonderful info! i was looking for something like this (rear drums adjustment and e-brake adjustment) and here it is! sweet! thanks for this thread
i believe same info applies to gen3&4 camrys/solaras except for models with rear discs.
