2005 Camry, any good? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2009, 09:04 PM   #1 (permalink)
View Brad1's Photo Gallery
I hope so. I just put money down on one. Found an immaculate '05 with 68k miles. Not a blemish on the car inside or out. Metal under the oil fill cap and the dip stick are nice and shiney and look like new. Brand new tires, brakes and state inspection. One year trasnferrable extended warranty left. $10k.
I've become a Toyota junkie since I bought my '94 Corolla 4 1/2 years ago. Still running that '94 (and loving it), bought an '02 Corolla for my Wife a few months back and I just put money down on this Camry.
Brad1 is offline   Reply With Quote
Old 09-21-2009, 09:09 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
i'd say you made a great choice. the 05-06 camry is arguably one of the more stable and problem free model years. the styling is great too! gen 5.5 ftw
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 09-21-2009, 09:29 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
Gen 5, 5.5 FTW!
Great choice! post pics!!
2002 Camry SE V6 "Snow White"
Old 09-21-2009, 09:39 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Exhaust pipe draggers...
Old 09-21-2009, 09:44 PM   #5 (permalink)
custom exhaust fixes that problem.
Old 09-21-2009, 10:17 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Keep an eye on the rear of the engine. The cylinder head bolts can pop loose because the threads disintegrated, causing coolant leaks from a loose cylinder head, slow at first.
People say it's a design defect or metallurgical defect. Not sure. If there are slightest signs, before warranty expires, get it in for a replacement engine.
Old 09-22-2009, 11:17 AM   #7 (permalink)
View AlmightyCamry777's Photo Gallery
Assuming theres no rust, you got yourself a great deal. I wish i'd have found such a car! I got my 02 V6 in 2006 and paid $15k out the door. It had about the same miles as yours did. I'm very happy with the car but I think i over paid!
AlmightyCamry777 is offline   Reply With Quote
Old 09-22-2009, 11:26 AM   #8 (permalink)
thats a good thing to know...do you suppose it could maybe be prevented by a retorque of the head at say every 50,000 miles? If i had the 4 cylinder engine thats what i would try, knowing what you just said...
If you want to retorque your cylinder head -
(by the way anyone who want to retorque their cylinder head be sure to read the proper sequence FIRST... it is ill-advised to just start tighening head bolts with no pattern - Certain conditions must be met to avoid permanent cylinder head warpage.)
Remember the block i think is aluminum. i know it is on the V6, as are the heads, not certain about the 4. To prevent the threads from corroding in the first place, i'd put anti-sieze compound on the threads of the bolts. If anyone knows a good reason not to use anti-sieze on the head bolts, i dont mind being corrected, but thats what i'd do.
1-engine must be STONE COLD (this means overnight cold - engine must sit for at least 8 hours). Do not attempt to torque the cylinder head on even a slightly warm engine - it can ruin the head.
2-proper bolt tightening sequence must be used. The sequence can be found here on TN.
3-the bolts are tightened in INCREMENTS not to final torque all at once, i.e. all bolts are tightened to about 1/3 final torque, then all bolts tightened to 2/3 of final torque, then all tightened to full recommended torque. Using the proper sequence each time.
4-unless stated otherwise recommended torque setting are for clean, lightly lubed bolt threads - (lightly lubed means 2 or 3 drops of engine oil - liken i said i'd use anti-sieze, high temp variety.)
Old 09-23-2009, 01:31 AM   #9 (permalink)
No, the problem is not with the bolts but with the cylinder block threads coming apart (metallurgical defect?). I need to google the Toyota TSB basically you need a new block when that happens. Not sure if Time-sert wil hold.
Old 09-23-2009, 01:39 AM   #10 (permalink)
I don't think 01507 is the right number about the block thread failure.
From Camry Forums:
buffitz
07-03-2008, 09:02 PM
Default Camry TSB 01507
How can I find out exactly what this TSB is for. I'm hoping its the faulty block (weak thread holes which caused a head gasket leak) that I had to replace. It says engine and engine cooling and the summary says 2az-fe engine block. *kb
