Originally Posted by redbrass_ca
Dear AlmightyCamry777
Thanks for all the pointers. I did my oil change with OEM filter on the car yesterday. I replaced the air filter , checked the battery dH20 level. According to the onwer's manual supplement the automatic transmission fluid is not required before the 96000 Km mark which is still another 10000 km away. The car underneath is in very good condition but the hardware on the exhaust system is starting to corrode and particulartly near the front bend on the exhaust manifold.
The brakes have not been inspected as of yet but I was told they were redone in August of this year
I will be rustproofing the entire car underneath with AD3000 from Lloyds. What are some of the worst area underneath the car prone to rust and corrosion? Perhaps I should start a new thread under rustprotection
Thanks
Terry
I change my ATF every 30,000 miles (just a drain and refill, my tranny has a strainer, and i left it alone so far).
When it comes time to fix the exhaust it is probably better not to patch, (adding a section of pipe here and a section there) change the entire thing if you can, as in my experience patching the exhaust system is futile. Many times the cat(s) can be reused for a while though, they are the most expensive single pieces.
Toyota provides fairly good rust proofing from the factory but there's no reason not to do some extra as you are doing, when i lived in snow i found most cars rusted out on the body sections behind the front and rear wheels. On older cars they would often start rusting from the inside of these areas and before you knew it, a tiny pinhole of rust became a fist sized hole, because it was from the inside out.
I'm sure your rust proofing kit comes with instructions on where to apply it and how, the most important things i would do is to keep the body water drainage holes open and not plugged up, and rinse the salt and thawed mud off the underbody and wheel wells with high pressure water whenever the weather goes above freezing.
