Tire Pressure Warning Light On, Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2009, 06:28 PM   #1 (permalink)
View hybryd40's Photo Gallery
Okay, I just went to Discount Tire today and bought new tires for my 07 XLE camry. Factory size is 215/60/16 and I bumped up to a 225/60/16. I asked them if they reset the sensors and they said yes. I just ran out to pick up something and the light came on. Do I need different sensors or do they just need to program these for the different size. I just went up one size. Any ideas ? Thanks
hybryd40 is offline   Reply With Quote
Old 10-01-2009, 06:34 PM   #2 (permalink)
View jkeith72's Photo Gallery
Have you checked the pressure? Maybe they are genuinly below the spec causing a legitimate light. If not, you can reset the light yourself. The switch is in the upper left of glove box recess...pic in the manual.
Tire size shouldnt play a role. Another thing, if all else fails....maybe they damaged a sensor installing the tire?
jkeith72 is offline   Reply With Quote
Old 10-01-2009, 06:35 PM   #3 (permalink)
View trooplewis's Photo Gallery
Your tire pressure warning light will only go off if one of the tires has a 25% variance compared to the other, the tire size should not make a big difference. So the first thing I would do is see if you actually have a low tire, which might be the case. Could have had a faulty valve stem or bad bead.
trooplewis is offline   Reply With Quote
Old 10-01-2009, 06:42 PM   #4 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
You should be at 35psi.
Redline_Me is offline   Reply With Quote
Old 10-01-2009, 06:44 PM   #5 (permalink)
I am thinking they just work off of pressure and not size of tires am I right? I will just go back tomarrow and have them rescan them.
Old 10-01-2009, 06:48 PM   #6 (permalink)
They measure the pressure because you can transfer them as some people have done with their aftermarket wheels.
Old 10-01-2009, 07:17 PM   #7 (permalink)
Yea, Thats what I thought. I will just take it back. Thanks
Old 10-01-2009, 07:22 PM   #8 (permalink)
Thanks guys, for all of the replys I will look more into it in the morning.
Old 10-02-2009, 06:37 AM   #9 (permalink)
Heading to work today and what do I see. Drivers side rear flat and drivers front half flat. Heading back to Discount to have fixed today. Not a happy camper right now. Good thing I have a air compresser, lol
Old 10-02-2009, 08:32 AM   #10 (permalink)
UPDATE : Went to the other Discount Tire ( closer to work ) and they said that the sensors were loose. They tightened and they are fine now.
Old 10-02-2009, 12:00 PM   #11 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $456050
View Luna2's Photo Gallery
Then it must have leaked air.........
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
