The left passenger side power window of my 2002 Camry hasn't been working for a while. I checked the corresponding fuse and it is fine. All other Power windows work normally. Today I opened the panel and took out the motor and tested. I tested the motor by operating with an external 12V source and no problem to move in either direction.
Then I checked the continuity of the wires coming to the rear door and to the motor lead. When I checked the continuity to the wire to the motor with a multi meter, it beeped even though I didn't press the switch. It shouldn't have any continuity when the switch is in neutral. Isn't it?
When I pressed down the switch, the beep stopped. If take off my hand it beeps and if I lift up the switch it beeps. So at both the neutral and up position, there is continuity but no continuity when I press down.
What is the problem here?
