Check Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2009, 04:13 AM   #1 (permalink)
Midnight Redy
Midnight_Redy's Avatar
View Midnight_Redy's Photo Gallery
Check Engine
Today I just noticed that my check engine light was on. I took the car to autozone and got a free checkup and they said it was my speed sensor... Have anyone have this problem before. I just got the car about 1month 1/2 or so. I dont think that it should have happen that quick.
Anyone out there had that prob?
Midnight_Redy is offline   Reply With Quote
Old 10-05-2009, 04:40 AM   #2 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $393350
View Luna2's Photo Gallery
Is your car new or used? Year, miles, model/flavor?
Have you done any brake work, or tire work, or installed a new electronic piece of equipment (stereo)?
Have you checked your fuses?
Details are very helpful, as to clues.
The Camry uses 4 wheel sensors, part of the ABS system & stability control, if equipped.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is online now   Reply With Quote
Old 10-05-2009, 04:53 AM   #3 (permalink)
Midnight Redy
its a 2009 camry bought it new with 5 miels in it. I did put some custome wheels in it but I dont think Thats the prob. Also I just installed some HID's the other day, but the engine light did not turn on till today. All I know is that today I went to Englishtown, NJ and the ligjt went on ( Checck Engine) Then I went to Autozone and have them check it and they said it was the speed sensor. After that I parked the car for 30mins at home then started it and the light was off. But im still going to tack it to the dealer just incase.
thanks
Old 10-05-2009, 05:08 AM   #4 (permalink)
Twin & (1 of 8)
Luna2's Avatar
thanks
It should have stored the code, and the dealer can read it and SHOULD be able to correct the problem, on the first attempt......
A loose connection at any wheel, or a problem in the ECU area or the IPC.
You didn't see the speedometer needle jump or sag?
New car, make the dealer fix it, make them note the problems on the service order properly, if it isn't correct, have the reword it.
KEEP COPIES OF ALL PAPER WORK..........
MFG 02/25/2010
Stock, Shucks!
Old 10-05-2009, 05:13 AM   #5 (permalink)
Midnight Redy
For sure. I will cll them in the morning. I purchased the at Sansome at rout9. I need to go there anyways cuz im due for a oil change and I prepaid it for 3 years.
No I did not see itt jumo or anything wrong. I was aware when i was driving the car but nothing exept the light was on.
Thank You
Old 10-05-2009, 09:30 AM   #6 (permalink)
View lyc70's Photo Gallery
thanks
It's not easy to confirm where the problem was generated, but new car seems having some strange problems when they happened there, dno't worry, probably they will be combined to smooth with your further drive, or it's better to change new one as the supplier's promise.
lyc70 is offline   Reply With Quote
Old 10-05-2009, 11:31 AM   #7 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $224200
did you write down the code? Could've atleast googled the code to see general solutions from other ppl
My Partial Partout!!!
Photo Album
Old 10-05-2009, 05:12 PM   #8 (permalink)
Redline_Me's Avatar
Gameroom cash: $335135
View Redline_Me's Photo Gallery
Don't bigger set of wheels/tires effect the speedo?
Redline_Me is offline   Reply With Quote
Old 10-05-2009, 05:16 PM   #9 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Bigger wheels don't. Bigger (or smaller) tires in overall diameter does effect the speedo.
Old 10-05-2009, 05:29 PM   #10 (permalink)
Paul_09WhiteV6
Gameroom cash: $588985
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
thats what i think he ment lammy. i'm 100% confident the wheels are not the problem. only way i think they could be is when they were installing them they broke or disconnected something but theres really nothing there to touch when removing wheels/tires that can make the light go on. i think it's a factor defect.
WrongFitmentCrew#628
Old 10-05-2009, 07:18 PM   #11 (permalink)
Redline_Me's Avatar
You're right, bigger wheels doesn't always mean that the overall diameter will get bigger.
Old 10-05-2009, 10:10 PM   #12 (permalink)
Midnight Redy
The code that hey provided me was found to be the Speed sensor.. I made an appointment for thursday. The light has not lite up since but im still goin to check it out.
Thank you everyone
