Brake Kit for 02 Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2009, 02:32 PM   #1 (permalink)
View Rajeev's Photo Gallery
Hello,
Been having brake fade problems, but now pads are worn and rotors need resurfacing or replacing.
So I'm looking into big brake kits but too expensive. Are there any upsize rotor packages that fit this car? Or from other cars' OEM parts? I do not do any racing BTW. Or I might just be stuck w/ stock size replacements.
Thanks for any info.
2002 V6 LE w/ 18" wheels
Rajeev is offline   Reply With Quote
Old 10-05-2009, 04:01 PM   #2 (permalink)
LoudCamry's Avatar
Gameroom cash: $181827
View LoudCamry's Photo Gallery
No need for big brake kit, just use some OEM one or OEM replacement rotor. You can alway upgrade your brake line to Stoptech SS brake line.
LoudCamry is offline   Reply With Quote
Old 10-05-2009, 08:49 PM   #3 (permalink)
That's what I figured... the most cost effective soln. I think I'll do that SS line as well... Thx.
If anyone knows other OEM's that fit though, please share. Larger setup would look nicer, esp. since I have the room.
Old 10-09-2009, 01:47 PM   #4 (permalink)
View AlmightyCamry777's Photo Gallery
I have the same car, i think if i were having brake fade problems i'd consider buying a ventilated (drilled) rotors if they have them available. I work on ford crown vic police cars and when their rotors wear out, we replace them with special drilled rotors- and those brakes NEVER fade.
Also i'd consider a switch to synthetic brake fluid since the Dot 5 is probably not meeting your driving requirements. The downside is that you have to take the brake system apart and clean it to switch between OEM brake fluid and synthetic.
AlmightyCamry777 is offline   Reply With Quote
Old 10-09-2009, 07:16 PM   #5 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
Camry brake fluid is typically DOT 3 not DOT 5. Synthetic brake fluid is typically compatible with conventional fluids, so a complete flush is not necessary... but its a good idea to do.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
