new intake. low idle rpm. yes ive used search - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2009, 07:18 PM   #1 (permalink)
djk
View djk's Photo Gallery
Gen5 new intake. low idle rpm. yes ive used search
so i installed a new intake on my 2003 xle (disconnected my battery and all that) and after checking to make sure all the lines were sealed and neat i started the car and the rpm kicked up past 1000 like usual but then it started to settle and then dropped down to zero shutting off the engine.
so i tried again but this time giving it some gas and turning on the ac/radio/lights and keeping the rpm up, after a couple minutes of this i took the car out around (for about 15 mins) but the rpm kept dropping really low and would begin to die if i didnt give it some gas. so i came back and trolled the forums for a little and read about cleaning off the MAF sensor so i went out and bout the MAF cleaner and disconnected my battery, cleaned the sensory thoroughly and tried again
turning on ac/radio/lights, giving it some gas brought the rpm down real low but the idle wasnt as rough. the idle settled around 300-500 so i felt safe enough to drive it around for about another 15 mins. this didnt seem to change much as after the idle still settled around 300-500 and then at the end the engine check light came on. any ideas? i wanna try to avoid the hassle of going to auto zone and getting it read. i included some pics of my setup to see if didn't connect something right or something
overall setup
closer
closeup of sensor attachments
djk is offline   Reply With Quote
Old 10-05-2009, 09:42 PM   #2 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
go drive around.
this happen to me b4.
i have a thread on it. and so do others
ecu needs to learn how to idle again
i had CEL also.
i just reset my ecu and it went away
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 10-05-2009, 09:48 PM   #3 (permalink)
djk
mm ive put about 30mins of driving time on it to see if itd adjust over, but for good measure i went out again about 45 mins ago, disconnected the battery again for about 30 mins and put it back, and then drove around again for about 10mins...same result
ah well worse comes to worst if it doesn't adjust over after a day or so i'll just put the stock intake back in
Old 10-05-2009, 10:00 PM   #4 (permalink)
View FLiPsta's Photo Gallery
mine took hours for it to adjust and even if you put back your stock intake it will still idle very low
FLiPsta is offline   Reply With Quote
Old 10-05-2009, 10:14 PM   #5 (permalink)
djk
did you ever get a check engine light?
Old 10-06-2009, 12:00 AM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
you have to let it relearn idle... stop disconnecting it and just leave it be.. just do regular local driving with stop signs all all that good stuff.. or even just sit in gear in your driveway. it will relearn
MrSo0h0o is offline   Reply With Quote
Old 10-06-2009, 12:21 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
put on your a/c, headlights, high beams, radio, ALL accessories. Put it in drive with the e-break up and just let it idle. It'll start to idle normally again
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 10-06-2009, 09:08 PM   #8 (permalink)
i love emmanuelle chriqui
LXS-mode's Avatar
View LXS-mode's Photo Gallery
+1 - 1 on the D and ebrake..
What is it about...Stance? Flushness? Stretch? or Pokin Out?
Clean...Elegant...Simple...yet so GANGSTA!!!
LXS-mode is offline   Reply With Quote
