I'm a little nervous today. I decided to get new wheels when I got new tires for my 2007 Camry LE v6. I bought Lexus IS250 wheels of Craigslist; they are 17x8 wheels, and are pictured in the OEM Lexus Wheel thread. I got the recommended 235/50R17 tires: Kumho Ecsta ASX's. This is the first time I've ever put different/larger wheels on a car.
got 'em installed yesterday at Discount Tire. Drove home, no issues. it was probably 10 miles. 1/3 streets, 2/3 highway doing about 70 mph. Only thing I heard was a slight "knockknock" noise as I did a 90% turn near my house (low speed).
Out of paranoia, I check last night to be sure the wheel isn't rubbing when turning all the way left and right.
This morning I drove down the street, turned on to a bigger street and hit 40 mph or so and there was a LOUD "KNOCKKNOCKKNOCK". handling seemed ok, car didn't seem to be shaking. I went back around a few blocks driving slowly, hearing the noise the hole time. PUlled into the garage. Looked around, nothing hitting or anything. Tighted all the lug nuts.
Left again, drove under the speed limit. The noise seems to increase in frequency as I drive faster. I don't really feel hard vibrations. The car handles OK.
My drive to work is probably 15 or 20 miles. Half the time on expressway (doing say 50mph today due to rain/congestion) and half the time on Chicago city streets. The noise improved (did not hear it all the time, was not as loud) but I still heard it even as I was pulling into the parking garage.
I've never heard a tire/car do this....
1. Any guesses as to what this is? Is it some kind of flatspotting problem that will go away as the tire "wears in?"
2. Is there anything special I need to do to keep these lugnuts tight? The old steel wheel used the acorn lugnuts (or self-tightening as my dad called them). The new wheel uses the "mag" lugnuts (there's some other name as well but I can't remember it) with a washer to hold the wheel on.
The car does handle firmer now, but obviously this has me worried.
I am no expert on wheels and tires like some of the other people on here, who may chime in later, but I would go back to discount tire to have them check everything out. Maybe even take one of the techs out for a ride to see what this problem may be. You may need spacers or other adjustments etc.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
I also need to run tests tonight -couldn't run them on the way home. I haven't been able to hear the sounds OUTSIDE the car, though on the way home I could feel vibrations more in the steering wheel than I could on the way to work. I'm gonna try running up and down the street with my head handing out of the car.
This may sound dumb, but I think the problem may be the lug nuts. I bought them from Autozone. I actually think they do not fit tightly in the "lug hole" in the wheel.
I work closer to home tomorrow, so driving won't be too horrible. I'm going to call the dealership early in the morning and see if they have 5 or 10 of these in stock.
if the lug nuts are not correct, you could very well get a lot of knocking noises. I would just go ahead and order all 20 from the dealership if you do not have the correct ones.
oh, also check out this thread (similar issue): Which are the correct lug nuts?
the part number for the lug nuts is there if you need it.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
Thank you; I have NO idea why I didn't see that before. The part number is helpful, and someone even mentions that the Toyota/Lexus bore hole is a bit large.
A close examination shows a slight cone shape on the lug nut hole on the wheel. The mag nuts I bought at Autozone are flat on the bottom. The mag nuts from Toyota have the slight cone shape.
You can tell a difference as soon as you put a Toyota lug nut on. It feels like you can tighten it to a point and then you're done - it's tight.
With the Autozone lug nuts, it never felt completely tight. It always felt like you could tighten it a bit more.
Now I just gotta add a torque wrench to the Christmas list.
