6th Gen Mirror Install Questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2009, 06:03 PM   #1 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Gen6 6th Gen Mirror Install Questions
Alright before anyone gets upset or mad about another thread and tells me to search. I apologize. I have read the other thread about 3 times already but cant find what I need and all the pictures are gone. I also downloaded the electrical diagram but didnt find the section on the mirrors
So anways I recently just bought these mirrors off of ebay
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
I am having trouble figuring out what each wire does on the mirrors and which to attach them into the car. The seller sent me some informationa and some blurry pics but nothing helpful so hopefully those that have these or similar mirrors can chime in and point me in the right direction. I also need help on where to tie the turn signal wires into.
The mirror has a plug with 5 wires 2 yellow, 1 white, 1 black and 1 brown.
I believe the 2 yellow are for the turn signal, i guess one for power and one ground?
Any and all help is much appreciated.
Thanks
-Drew
The mirrors
And the plug and the 5 wires
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 10-22-2009, 07:10 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Thanks man, I have seen this already and it still doesnt make sense
Indicator off - Yellow (outer) = GND, Yellow (inner) = GND
Indicator on - Yellow (outer) = GND, Yellow (inner) = +12v (only when light is lit up)
Mirror up - Brown = GND, Black = +12v
Mirror down - Brown = +12v, Black = GND
Mirror left - Brown = GND, White = +12v
Mirror right - Brown = +12v, White = GND
How can you use the same wire twice? Do you have any pics of where you
Old 10-22-2009, 07:34 PM   #3 (permalink)
My other cars a DSM!
View BiGbodyANT's Photo Gallery
kind of off topic but did those mirrors come white like that or did you have them painted already?
BiGbodyANT is offline   Reply With Quote
Old 10-22-2009, 07:35 PM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
yea they come like that, i am getting them painted next week just want to get the wiring down.
Also are both turn signal wires found under the drivers side kick panel? and if so which wires.
Thanks
Old 10-22-2009, 07:48 PM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
You can't find the electrical section on mirrors and you can't find the electrical section on turn signals either?
and they sure don't look like LEDs....................
Old 10-22-2009, 07:55 PM   #6 (permalink)
Go camry goooooo
DrewsCam's Avatar
was waiting for you to post up, hopefully you can help me out
Old 10-22-2009, 08:28 PM   #7 (permalink)
MOD's = Addiction
Dhanlal89's Avatar
View Dhanlal89's Photo Gallery
Gen6
for the turn signals i tapped into the wires that are running from the driver kick panel to the tail lights, just look at your rear taillight turn signal bulbs an check out the color on those wires, then u can trace the wires running to the back coming from the driver side kick panel....i cant remember the colors off the top of my head or i would just tell you lol, and i extended the passenger side turn signal mirror wires and same with drivers side turn signal wires to the kick panel
hope this helps
08 i4 / TEIN / Prosport / Dual TRD Cat
LED Tailights / 6000K:3000k HID's / Custom Decal
Dhanlal89 is offline   Reply With Quote
Old 10-22-2009, 08:33 PM   #8 (permalink)
Go camry goooooo
DrewsCam's Avatar
hope this helps
Thanks man, I was thinking of doing that. I will take a look once I get them up and running I will put together a DIY. Do you remember how the ones from the mirror went to the car. So what about the 2 yellow from each mirror? Which gets hooked up to the signal and what about the other one? Do I just ground it?
I found this
Brown connected to Black/Dark gray
White connected to Purple/Dark Blue
Black connected to Brown
Old 10-22-2009, 09:19 PM   #9 (permalink)
MOD's = Addiction
Dhanlal89's Avatar
Gen6
there were two wires coming from the bulb and i just connected both to the wires and tested and it works fine, if it doesnt then jus swap them and that should be the difference, im sure one is a positive an ground but you could probably connect it to another ground if you want (instead of running two wires), i dont see why that wouldnt work...... yeh that color combination is coming bak im pretty sure that right...make sure to test before anything final is hooked up, which im sure u kno lol
Old 10-23-2009, 03:57 PM   #10 (permalink)
View camnut's Photo Gallery
Mirror Wiring
This link will help you tap into the wires behind the kick panel. Can't help you with the wires on the mirror.
http://www.kwmuth.com/techsupport/pdfs/21001260.pdf
camnut is offline   Reply With Quote
Old 10-23-2009, 04:43 PM   #11 (permalink)
Go camry goooooo
DrewsCam's Avatar
thanks guys and thank you njerald for that pdf
I am bringing the covers in to be painted next week and will have them put in after they get painted
Old 10-23-2009, 05:20 PM   #12 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
You installing them yourself or you going to end up having a shop install them?
CarDomain
Old 10-23-2009, 06:31 PM   #13 (permalink)
Go camry goooooo
DrewsCam's Avatar
I'm doing it, just needed some guidance
Old 10-25-2009, 12:54 AM   #14 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
yea.... they don't look LED...
My Partial Partout!!!
Photo Album
Old 10-25-2009, 01:04 AM   #15 (permalink)
must.resist.modding
bandit's Avatar
They arent LED. These were the ones jayb82 or something like was selling on the forums a while ago. These were OEM from overseas. Similar to what lammy has or is it the same?
CarDomain
