Storage compartment door in dash won't open - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2009, 03:10 PM   #1 (permalink)
View phlip's Photo Gallery
We recently bought a 2010 Camry. Last night, I put something in the storage compartment in the dash and closed it's door. This is the compartment behind the gear shift. I can't get the door to open now. Anyone have any suggestions on how to get it open?
phlip is offline   Reply With Quote
Old 10-25-2009, 03:21 PM   #2 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
happened alot to me in the past because my wires get stuck. now, I always make sure all wires are pushed in before i close...
anyways, i was afraid to break it but you can try slippin some thin paper or plastic or wedge, to try to push free anything stuck on the bottom.
also you can apply some pressure on the top half as you push. it might help wedge the door open again
skyxliner is offline   Reply With Quote
Old 10-25-2009, 08:04 PM   #3 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
Sounds like a well designed system.
johnfrisco is offline   Reply With Quote
Old 10-25-2009, 08:39 PM   #4 (permalink)
Streaker
Gameroom cash: $121159
View Streaker's Photo Gallery
Slide a credit card partly under there and sweep it side to side, then press the bottom of the door in as far as it will go and pull the card out.
2007 Camry SE Titanium Metallic V6: Muth signal mirrors, 18" TSW Mondello wheels, Crimestopper alarm/remote starter.
Streaker is offline   Reply With Quote
Old 10-26-2009, 03:31 AM   #5 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
This happened to me a few times with wires leading out (don't forget, there's that small hole on the right side with the punch-out plastic piece).
Depress the panel, and use something flat, with a odd end (ie: bent coat hanger) and pull outwards.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
