2005 Camry Standard (CE) Adding Factory keyless entry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2009, 09:52 PM   #1 (permalink)
View shmeccher's Photo Gallery
Gen5 2005 Camry Standard (CE) Adding Factory keyless entry
Hello
I just bought an '05 camry standard CE which doesn't have the factory keyless entry. I was wondering if anybody tried or succefully added the factory keyless entry. Does anybody know if its wired up so you can just put the control modules and sensors? Where are they located in the car? They are sold on ebay relatively cheap and I was wondering what parts I need to complete this project. I hate aftermarket alarms, factory is alot better
Thanks in advance
shmeccher is offline   Reply With Quote
Old 10-27-2009, 09:55 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
We just went through this is the last couple weeks with a GEN6 CE thread....
Old 10-27-2009, 10:03 PM   #3 (permalink)
Is there any links available?
Old 10-27-2009, 10:14 PM   #4 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
If you search for "keyless entry" I'm sure you'll pull up some good information.
My opinion.. The factory system integrates better (priority unlocking, nice piezo sensor chirp, dome light supervision, turns off the headlights if you hit lock twice etc..) but I don't regret replacing it with a Viper alarm system on my Camry. Longer range, better protection, and lots of custom options.
Good luck!
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 10-27-2009, 10:19 PM   #5 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
A search on the forum will yield many results....
Upgrade to key with remote
Installing Keyless Remote on 07 Camry
Full results..
http://www.toyotanation.com/forum/se...archid=2430883
CarDomain
Old 10-27-2009, 10:21 PM   #6 (permalink)
Good luck!
I tried doing some reasearch on this with no luck. I'd prefer the stock, I had too many problems with aftermarket in my other cars
Old 10-27-2009, 11:01 PM   #7 (permalink)
Originally Posted by dcemureviews View Post
Thank you for posting these links but most of them are for '07+ camrys. Do you know by any chance if the '05 and '07 camrys have the same wiring and keyless entry module? Would It be possible to buy a kit from the dealer for '07 camry and istall it in my '05 cause I don't think they made a kit for '05-'06 models
Old 10-28-2009, 08:41 AM   #8 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i personally did the VIP RS3200 + for my 2003 camry SE,
there are two different types,
one is for no keyless entry, no alarm, VIP RS3200
one is for keyless entry, but no alarm, VIP RS3200 plus
my 2003 camry SE only came with keyless entry, no alarm, but pretty much directly plug in, no wire splice, tapping, just need to take off all the cover from side kick, under dash, steering column cover to get to the connectors.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 10-28-2009, 09:04 AM   #9 (permalink)
must.resist.modding
bandit's Avatar
I would assume that if your came came with no keyless entry or alarm, it wont have wiring. I could be wrong. Why not go to dealer and ask them?
I know you said you wont get aftermarket but you're better off. Factory isnt always better in this case. For example, the remote start for Gen6 sucks. You remote start the car and the engine shuts off when you open the door. Which than requires you to turn the ignition. Aftermarkets keep the car running when you open the door and turn the ignition. Unless you press the break without key in ignition.
In one of those links, is a link to service manuals at camrystuff. Go and compare wiring to both Gens and see for yourself if they have the same wiring.
Get an aftermarket alarm/entry installed by a professional or authorized installer and call it a day. Any problems, its covered with warranty and installer can fix it.
CarDomain
Old 12-10-2009, 04:33 PM   #10 (permalink)
USA
I succesfully installed the factory keyless entry on my 05 camry CE
Old 02-23-2010, 06:13 PM   #11 (permalink)
View Fauxtanium's Photo Gallery
What was involved as far as parts/cost? I just got one ('05 CE) myself.
Dave.
Fauxtanium is offline   Reply With Quote
Old 02-23-2010, 06:33 PM   #12 (permalink)
Dave.
I created a pdf file with instructions and what you need download it here http://www.filebox.com/oavlweikhiyr
Old 11-28-2010, 09:55 AM   #13 (permalink)
View kjarrett's Photo Gallery
This link is bad - can you repost the PDF? Thanks!
-kj-
'05 Rav4 L
'97 Camry LE
kjarrett is offline   Reply With Quote
Old 12-03-2010, 12:04 AM   #14 (permalink)
-kj-
try this link http://www.mediafire.com/?6ttth8jh924yx4l
Old 02-05-2012, 11:02 AM   #15 (permalink)
View taswon's Photo Gallery
Can you please share the PDF you made with the instructions to install keyless on a camry. Mine is an 07 but shouldnt be too different from the prev gen
taswon is offline   Reply With Quote
