Originally Posted by dpico
have a 2002 toyota camry le with trans prob. it is slipping out of drive when i make a stop and sometimes when i go into reverse. have 117k miles on it. need to rebuild this transmission,anyone know what is the quickiest way to remove (from the top or bottom)? Also want to rebuild trans myself. Any good service manuals out there? anyone have any pixs? anything will help.
Thanks guys.
Before you go with the diagnosis of a "rebuild needed" make sure you've eliminated silly problems like a badly adjusted shifter linkage. You can get docs at
http://www.camrystuff.com/ - the manuals there will show the correct shifter adjustment process.
The manuals there also show how to R&R the trans - Section 40, around page 10. It's an unpleasant enough task, but not horribly complex. Just make sure you have the right jack stands and tools to properly support the parts as you remove pieces of the drivetrain.
