looping back tube to improve airflow and intake? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2009, 07:45 PM   #1 (permalink)
View renx215's Photo Gallery
I drive an 07 camry SE. a friend of mine basically moved some tubing near the intake area that he claims improves airflow/intake, I have before and after pictures of what He did. Can someone give me a second opinon?
1.) Here in the unmodified image you can see two tubes coming from the left side going into to different things.
2.) Now in this second picture he rerouted the tubing so that on the left side one tube is looping back into itself, and the two parts that were tubed to that originally are now tubed together by the darker grey tube.
Thoughts? Or can someone offer me a better explanation?
renx215 is offline   Reply With Quote
Old 11-03-2009, 07:52 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $476710
iTrader Score: 12 reviews
View bandit's Photo Gallery
Your friend probably got it from here (starts around 3 min mark)..
I've tried it and there was no difference.
It has also been discussed here - 2007-2008 DIY K&N intake mod video
CarDomain
Old 11-03-2009, 08:02 PM   #3 (permalink)
81Bluebomber's Avatar
View 81Bluebomber's Photo Gallery
I would say put it back. Unless someone has done a Dino run on this mod. I say its crap.
2007 Tundra 5.7
81Bluebomber is offline   Reply With Quote
Old 11-03-2009, 08:04 PM   #4 (permalink)
Thats probably what im going to do. I just bought the car a month ago with only 17K. Coming from a corolla i love everything about it. The only thing I've done is add a k&n drop in filter, tints, and HIDs. Any suggestions on improving MPG? this is the V6 model
Old 11-03-2009, 08:08 PM   #5 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
http://www.cardomain.com/ride/2379023/3
Or here... First gen6 to do it =P
The looping back together is not the key to this mod... I removed the sensor all together. The key is the bypass straight into the intake tube.
What it does is switch the vacuum lines to keep the intake valve open at all times... it draws cooler air at all times
My Partial Partout!!!
Photo Album
Old 11-03-2009, 08:26 PM   #6 (permalink)
Somewhat a Lurker
Gameroom cash: $311569
View Agent556's Photo Gallery
Ok, this really caught my interest. Is this possible for the gen 5.5 V6 or is there no second valve that opens at higher RPMs in the first place?
Agent556 is offline   Reply With Quote
Old 11-03-2009, 08:30 PM   #7 (permalink)
Ok so in essence, Whats the benefit here? Whats the potential risk? And can someone tell me how the heck your suppose to install an HID kit in the fog lights?
Old 11-03-2009, 08:35 PM   #8 (permalink)
Somewhat a Lurker
I don't really know how it works, but it seems that there is a valve in the intake that stays closed at low RPMs and opens up at higher RPMs to allow more air in as the engine needs it. This mod keeps that valve open so that even at low RPMs, the engine gets more air.
I'm pretty sure the gen 5 intake has a valve like that too, going to look into it, and hoping someone already knows also.
Old 11-03-2009, 09:16 PM   #9 (permalink)
Not-So-New TN User
Netforcer's Avatar
This mod DOES NOT give the engine more air. Like I said before, it only give the engine cooler air at all times by keeping the front valve open at all times. Air entering the engine is controlled by the butterfly valve in the throttle body and not this mod. The only way to get more air into the engine is going forced induction.
Photo Album
Old 11-03-2009, 10:40 PM   #10 (permalink)
Somewhat a Lurker
My bad, that's what i meant
ill be taking a look through the engine bay this weekend to see if this is possible on a gen 5 also
Old 11-18-2009, 06:24 PM   #11 (permalink)
does this improve mpg? I noticed my 07 camry se v6 is only getting about 220 or miles on a full tank. I bought it 2 months ago as a certified vehicle. It had less then 17k on it. Any ideas?
Old 11-18-2009, 10:09 PM   #12 (permalink)
Not-So-New TN User
Netforcer's Avatar
nope... it shouldn't... try changing your driving habits... it'll have a bigger impact than any mods
Photo Album
Old 11-18-2009, 10:26 PM   #13 (permalink)
must.resist.modding
bandit's Avatar
CarDomain
Old 11-19-2009, 09:21 AM   #14 (permalink)
View JFD27's Photo Gallery
full synthetic oil, clean air filter, spark plugs shouldnt be a problem. also check the tire pressure in all four tires and as stated above change your driving habits
JFD27 is offline   Reply With Quote
Old 11-19-2009, 11:23 AM   #15 (permalink)
thanks..seeing how I bought it from toyota with only 17k on it I really don't think any issue is there. Like when I switched to a k&n drop filter, the one they put in was new. I understand its a V6, and I don't drive like a mad man. About 70% of my driving is city. So I definitaly feel something is wrong. On average how many miles should I be getting realistically off a full tank? I'm at the half way point with 112 on the trip odometer...now considering it holds 18.5 gallons I'm thinking I should be getting more. Thanks guys. As this my first camry, upgrading from the corolla.
