Originally Posted by kimmir
Hi,everybody!
I got VSC and TRAC OFF lights on,pull out C1336 code.What does it mean?
Thanks!
C1336 means "zero point calibration of yaw rate sensor undone." The yaw rate sensor feeds into the VSC, so if it isn't working, the VSC won't work and you'll get the "VSC / TRC" light. I think you need to have a Toyota dealer or specialist Toyota mechanic look at this one. Don't mess around with this. Your stability control and traction control aren't working right now.
1. Brake actuator assembly (Skid control ECU)
2. Yaw rate and acceleration sensor
3. Zero point calibration undone
