07 XLE brake torque specs?
Hey everyone -
I'm new to the form and wanted some help with an upcoming maintenance task. I am helping a friend out with a brake pad/rotor replacement and have been looking for the torque specs. I haven't worked on a Toyota before (all my prior experience is w/Honda cars), but from what I've read, the brake caliper design is fairly similar to what I've worked with.
So instead of going out and getting a Haynes or Helms for a one time job, I thought I'd post here to ask for some info.
I need to know two things.
1. The torque specs for:
-caliper mounting bolts
-pad holder bolts if they exist? I'm not sure if Toyota uses these. It's a holder which has the rails that the pads move on. They screw into the knuckle from the rear.
-wheel lugs (I'm guessing 75-80 ft-lbs)
2. The brake bleeding sequence. What wheel order should I follow?
THANKS!
