Need Help with engine/VSC/Traction Control light on 07 CAM V6 Auto - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2009, 02:54 PM   #1 (permalink)
View SECAM07SIL's Photo Gallery
Angry Need Help with engine/VSC/Traction Control light on 07 CAM V6 Auto
First off i just want to say that I love my Camry. I drove it right off the truck and only had 2 miles on it. Everything has been great. No problems at all. I bought it in 2006. I put 75K on it. I sold Toyota's for over 3yrs, but got out of the business after a move back to Colorado from LV, NV and after the market went down. Anwyays here is my problem, maybe I can get some insight to it before I take it in.
The other night I avoided an accident. In doing so I hit my gas and peeled out for about 15 ft or so. When I was about home I saw all three lights engine, VSC, and Traction control light on. It must have been on for a while, but the car drove fine coudln't feel anything wrong. When I parked I sat in it for a while and the VSC, and Traction lights turn off, but engine light on. When the car starts to move, all the lights come back on, but again the car runs fine.
The next day I called service and told them what happened. They told me that I may have tripped my sensors, and the car should be fine to drive until I bring it in. Now I have been driving it the whole week and what do you know...all the lights turn off, and stay off until.....last night when I was merging on the highway I pushed the gas all the way down when the car reached about 4500-5000 rpms the engine cut power or feels like there is a lack of power after that I let off the gas and all three lights are back on. it runs fine but when the engine climbs or when I step on the gas and rpms go up it seems like the engine is choking or something. I once again sat in the car for a while and let the car idle sometimes the engine vibrates/choking for a few seconds and stops I don't know what the hell is wrong, but if anyone has any insight I would be greatly appreciative. Thank you
Adam
SECAM07SIL is offline   Reply With Quote
Old 11-20-2009, 05:29 PM   #2 (permalink)
No one?
Old 11-20-2009, 08:04 PM   #3 (permalink)
81Bluebomber's Avatar
View 81Bluebomber's Photo Gallery
Take it in. The computer needs to be checked for codes and then the tech can go from there.
2007 Tundra 5.7
81Bluebomber is offline   Reply With Quote
Old 11-20-2009, 10:29 PM   #4 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
Try this threads, and take it to dealer
vsc and traction control light is on!
ABS, Trac, and VSC lights
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 11-21-2009, 12:58 AM   #5 (permalink)
thanks guys
Old 02-07-2010, 02:35 PM   #6 (permalink)
GrayCam
View GrayCamrySE07's Photo Gallery
SECAM07, did you ever find out what the problem was with your check engine, VSC and trac light? Just curious as the same thing is happening to my wife's 07 Camry SE 6Cyl Auto. I have an appt to bring it in to the dealer but just thought if you knew what they ended up diagnosing the problem as?
GrayCamrySE07 is offline   Reply With Quote
Old 02-27-2012, 10:30 PM   #7 (permalink)
Camry-Jennifer
mcnitt_jennifer's Avatar
View mcnitt_jennifer's Photo Gallery
Same problem
I installed a sub and amp in car and now seem to be having the same problem. At first none of the instrument cluster worked. Husband jiggled the wires under the fuse box and now the cluster mostly works, but VSC light, Traction control light, and check engine light are all ON. Will take to dealer tomorrow. When the find the solution, I will post what was wrong, but meanwhile, if anyone has any suggestions or fixes please let me know.
mcnitt_jennifer is offline   Reply With Quote
