When replacing the brake pads on a 2004 Camry XLE (4 wheel disc brakes), do you need to rotate the piston while pushing it back into the cylinder or will just a large C-clamp work correctly? On my Mercury Sable (also four wheel disc brakes), the C-clamp worked fine on the front (used the old pad between C-Clamp and piston to protect the piston), but the rear pistons, because of the parking brake, required I use a tool to rotate the piston while pushing it back into the cylinder. I have not found any reference to needing to do that on the Camry rear disc brakes and in fact, one thread recommended against it. How do you deal with disc caliber/pistons that the parking brake operates? Thanks!
David
the rear breaks on the camrys are a drum-in disk design. WHich means the parking brake is seperate from the brakes
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
Thanks everyone, for your response. The "drum in disc" design comment was the revelation that caused it all to make sense. I was having difficulty understanding the diagram in my .pdf service manual because the parking brake section is different from the "brake" section and it looked like it applied only to drum brake models.
Reason: left off last 11 words.
Just my 2 cents, but it is just one more reason why we should have drums at the back. 20% of your braking at the back.
Just think of it we have a disk and a drum at the back.
All this extra garbage just to have a handbrake work well. Because the disk handbrakes do diddly.
I actually prefer the drum-in-disc type. You actually have two independent brake systems back there. One operated by hydraulics and the other purely mechanical.
i wish my car had drum in disc. old drum design look like shit, all rusted, pain to clean often. also you can see huge drums through stock alloy wheels which is not nice, unless you clean them periodically.
besides changing disc brake pads is like a spit in comparison to changing drum shoes and doing routine maintenance on drum components ...
just my 2 cents.
Yes, I guess your right it is built in redundancy which is always good.
My point was more about the need for disks in the rear.
An a cable for that hand brake would of been just fine to a drum.
I know what you mean. Those brake drums showing through the alloy wheels. What horrible sight!
