Popping Noise and Rotational Noise at Highway Speeds
When I place my Camry in reverse and turn the steering wheel to the right I hearing several popping noises coming from what conclude is the right front end. Once I get to highway speeds (50 mph) I hear a rotation noise similar to that commonly associated with flat spotted tires. I have had the suspension checked and tires rotated by several vendors since the noises and sounds started. I believe that the noise from the right front end is either a sway bar, a constant velocity joint, a wheel bearing/hub, or some sort of steering linkage. The noise at highway speeds preplexes me. It might be a wheel hub/bearing issue or possibly resonance. Is there an easy way to diagnosis the problem(s)? Is my logic on the right track or am I way off?
