02 Camry 4cyl dying while idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2009, 04:47 PM   #1 (permalink)
View NFSPD's Photo Gallery
I have on 02 Camry that dies after being idle for a few minutes it idles way down really low then dies.
What are the main causes of this so i can do a check.
thanks
NFSPD is offline   Reply With Quote
Old 12-08-2009, 08:45 PM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
I'm guessing that is is an I4? There are a number of things but the simple and cheap things to look at first would be all the vacuum hoses in there that might be leaking. I assume the check engine light is not on? The MAF could be gunked up and needing some cleaner. These are things you can do yourself for cheap. Start there.
gdanaher is offline   Reply With Quote
Old 12-08-2009, 09:47 PM   #3 (permalink)
I callz it like i seez it
View ScrooYoo's Photo Gallery
how old is your battery? an old battery can also cause this. one of the signs is if it sounds sluggish when you start it.
ScrooYoo is offline   Reply With Quote
Old 12-09-2009, 01:39 PM   #4 (permalink)
vvti-me's Avatar
View vvti-me's Photo Gallery
im a mechanic heres the possibilities. 1. did you disconnect your battery recently? if so your car needs to relearn the idle process and the drive cycles. just drive it a lot preferably on the highway as well so your car can relearn the drive cycles. 2. check for vacuum leaks. 3. your throttle body might have too much carbon build up so you can clean that with intake cleaner. 4. your ICV idle control valve could be bad. usually the problem is the idle control valve.
vvti-me is offline   Reply With Quote
Old 12-09-2009, 02:58 PM   #5 (permalink)
View FireLikeIYA's Photo Gallery
If you run an oiled filter such as a K&N it could be that your MAF has some oil/gunk built up on it. This will look like a small gray cotton ball on the sensor. Try not to touch this sensor to clean it. They sell MAF cleaner at some auto parts stores. It literally takes two seconds to clean and your car will run like new.
FireLikeIYA is offline   Reply With Quote
Old 12-09-2009, 05:35 PM   #6 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
it's an I4, I don't believe they have an IAC valve. To the OP, clean the throttle body and the MAF... simplest and quickest things to try.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 12-09-2009, 09:18 PM   #7 (permalink)
ok will try cleaning those
plus the car was sitting for awhile so i had to charge the battery so it may just need to learn. Everything was fine before it got stored for 3 months.
But now i notice my a/c isn't working and the light is blinking
