this what i order when i did a 90k service
1. Water pump
16100-29085
2. Timing belt
13568-09080
3. alternator belt
4. power steering belt
99366-21040-83 and 90080-91088-83
5. front crack seal
90311-40022
6. Cam seal
90311-38034 (need 2)
7. spark plug.
90080-91180 (need 6)
Those are the main items but if you are changing your cam seals you should also then replace the valve cover gaskets (11213-0A010 and 11214-0A010) and spark plug tube seals (11193-0A010 x6). A 90k also consistsa of your filters; are you looking to replace those as well?
