Originally Posted by johnnyzee
wish i could help, all I can think of is software, but if the tranny was working fine before this sloppy shifting occured, software wouldn't be the issue either.
other than being a broken tranny,
could it be bad signal / poor grounding? I've heard that some "big 3" grounding kits help auto trannies shift faster, smoother. Haven't tried it personally, but for now check the grounds, electrical connections.
hopefully someone else can chime in.
There is a known problem with the software on 2002 models from what I gathered on
http://consumerguideauto.howstuffwor...ta-camry-2.htm
Poor transmission shift: Early production vehicles with automatic transmissions may shift poorly. The revised engine-control module designed for 2003 models can be installed in older vehicles. (2002) "
My problem appeared over night so I am not sure if that applies to my car. I need to do some more research to find out which ECM's this problem affects (The part numbers that I obtained from my ECM are as follows 89666-06220 and TN275000-1882). The car was built in Oct '02 so it may not apply. I have found used 2003 ECU's online for ~$70 but there are quite a few different model numbers.
Where can I find information on the "Big 3" grounding kit?
Thank you for your help. I too am hoping someone chimes in who has experienced the same symptoms.
