How to adjust foot-pedal parking brake on XLE model? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2009, 05:45 PM   #1 (permalink)
View Sella Turcica's Photo Gallery
I searched and found info on how to adjust the console-mounted parking brake lever on the Gen 5 camry, but I have a foot-pedal parking brake on our XLE. Does anyone have info on this? Ours groans and slips on a hill.
thanks
2003 Camry XLE 2.4L
Sella Turcica is offline   Reply With Quote
Old 12-09-2009, 06:11 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
thanks
Remove the rear wheel, and then rubber plug on the drum. Disengage the parking brake. Turn drum so that the hole is somewhere in the 5 to 7 O'clock position. There is an adjusting gear in there that you turn to adjust the brake shoes. Expand it to maximum so that the drum can no longer turn. Retract about 6 clicks. Repeat for other side.
2007 Camry 2.4L 5M
Old 12-09-2009, 06:36 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
ADJUSTMENT
REMOVE REAR WHEEL
ADJUST PARKING BRAKE SHOE CLEARANCE
(a) Temporarily install the hub nuts.
(b) Remove the shoe adjusting hole plug.
(c) Turn the shoe adjuster and expand the shoe until the disc locks.
(d) Turn and contract the shoe adjuster until the disc can rotate smoothly.
Standard: Return 8 notches
(e) Check that there is no brake drag against the shoe.
(f) Install the shoe adjusting hole plug.
(g) Remove the hub nuts.
INSTALL REAR WHEEL Torque: 103 N*m (1,050 kgf*cm, 76 ft.*lbf)
Repeat for other side....
INSPECT PARKING BRAKE PEDAL TRAVEL (for Automatic Transaxle)
(a) Fully depress the parking brake pedal and release it to engage the parking brake.
(b) Depress the pedal to the floor again, and release it to disengage the parking brake.
(c) Slowly depress the parking brake pedal to the floor, and count the number of clicks.
Parking brake pedal travel: 7 to 10 notches at 300 N (31 kgf, 67 lbf)
ADJUST PARKING BRAKE PEDAL TRAVEL (for Automatic Transaxle)
(a) Depress the parking brake pedal. Hold the No. 1 wire adjusting nut using a wrench and loosen the lock nut.
(b) Release the parking brake pedal.
(c) Turn the No. 1 wire adjusting nut until the parking brake pedal travel meets the above specification.
(d) Hold the No. 1 wire adjusting nut using a wrench or an equivalent tool and tighten the lock nut.
Torque: 5.4 N*m (55 kgf*cm, 48 in.*lbf)
(e) Count the number of clicks after depressing and releasing the parking brake pedal 3 or 4 times.
(f) Check whether the parking brake drags.
(g) When operating the parking brake pedal, check that the parking brake indicator light comes on.
Old 12-10-2009, 04:41 AM   #4 (permalink)
thanks!
2003 Camry XLE 2.4L
