Air Filter Change, Help, 4 cyl 2007 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2009, 03:51 PM   #1 (permalink)
View dustoff's Photo Gallery
Air Filter Change, Help, 4 cyl 2007, EDIT- Now w/pics
I changed the air filter and noticed the new air filter sticking out a bit on the left side facing me (not the firewall). Same problem as this thread. why is a little bit of engine air filter(white part) showing? is this normal? I don't remember seeing it before I changed the filter.
It seems like the housing isn't sealing perfectly. Some people say it's normal and others say it's not. What's the consensus? If it's not normal how do I fix it?
The square corner of the filter goes on the left side toward the firewall, right?
If I close the box without any filter, it's obvious that the two halves fit very easily and the bolts fall into their holes without any help. With the filter, you need to adjust the bolts a bit.
njerald says there were 3 or 4 other threads on this topic, but I couldn't find them.
EDIT:
I finally got around to taking pics of what the problem looks like. I know I put the filter in correctly. I'm using a Fram.
Air filter is the white thing.
1st pic: Problem area is circled
2nd pic: View from the battery side
3rd pic: View from the engine side
Anybody else have an air filter that sticks out like this? Please note whether you're using a Toyota filter or not.
dustoff is offline   Reply With Quote
Old 12-13-2009, 05:05 PM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
You have to follow the tab, match the shape of the filter with the air box. My K&N fits perfectly.
I have my DIY somewhere in here..
GT-R is offline   Reply With Quote
Old 12-13-2009, 05:46 PM   #3 (permalink)
Right here. How to change engine Air Filter
I guess I'll try again.
Old 12-14-2009, 10:50 AM   #4 (permalink)
Ok I checked it this morning and the filter follows the shape of the air box so it was placed correctly. Any other position wouldn't close the box.
I still don't know why I can see that corner of the air filter. Depending on placement, I can also see a sliver of the left edge. I used a Fram, but the original factory filter does the same thing. I guess this is normal.
Old 12-14-2009, 11:23 AM   #5 (permalink)
View mcdawgg's Photo Gallery
I looked at mine before I replaced it for the first time. Changed it (very easy to do) and it looks the same as before I changed it - you can see just a very small part of the left edge (looking at it from the front of the car.)
mcdawgg is offline   Reply With Quote
Old 12-14-2009, 12:50 PM   #6 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
If the cover is snug against the fileter, then don't worry about it. You may have bought an after market filter and from experience they all aren't made exactly nor do they fit precisely as oem.
gdanaher is offline   Reply With Quote
Old 12-14-2009, 01:00 PM   #7 (permalink)
View Angel760's Photo Gallery
Most likely its not going to fit perfectly snug like an OEM would. but its normal as long as it fits in the box and get the right theading on the bolts.
Angel760 is offline   Reply With Quote
Old 12-15-2009, 12:23 AM   #8 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
The sharp corner has to be in the far left corner when looking at the air box from the front of the car.
Redline_Me is offline   Reply With Quote
Old 01-06-2010, 02:19 PM   #9 (permalink)
Bump. Pics are in the first post.
Old 01-08-2010, 03:06 AM   #10 (permalink)
Gameroom cash: $189254
View kotori's Photo Gallery
my V6 has the same thing, don't worry about it, it's just a little on the edge. If you didn't put it in correctly, you wouldn't be able to close the lid
kotori is offline   Reply With Quote
Old 01-08-2010, 06:30 PM   #11 (permalink)
I was concerned because it doesn't seem like a good seal. I don't want any dirt getting into engine through the edges. It would defeat the purpose of the filter.
Old 01-09-2010, 10:27 AM   #12 (permalink)
carlo$'s Avatar
View carlo$'s Photo Gallery
I can't believe the shi**y design toyota did on the air filter box of my 05. very lame!
2005 LE 4 cyl
carlo$ is offline   Reply With Quote
