Air Fuel Sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2009, 06:28 PM   #1 (permalink)
View toycamry's Photo Gallery
Air Fuel Sensor
My 2002 Camry use kick a code P1135, air/fuel sensor heater. Is the sensor located in the engine bay in front of the radiator? Do it look like a standard O2 sensor? Is the O2 sensor have a plate and held in by studs and bolts? Is Denso the sensor of choice or is Bosch OK to use? The engine is a 4 cylinder and think it may be a California emission, I'm in Mass.
Thanks
Mike
toycamry is offline   Reply With Quote
Old 12-15-2009, 07:39 PM   #2 (permalink)
View hossmaster's Photo Gallery
Usually that code means that the sensor is done. I believe that this sensor is the one that is right on top of the exhaust manifold, right on top of the exhaust. It is screwed into the manifold. I would spray it with a good penetrate like PB Blaster or Sea Foam Deep Creep, WD40 is meh. Do not get Bosch, go to the dealer or get the Denso replacement. Also it is not called an O2 sensor, it is called an Air/Fuel Ratio Sensor.
hossmaster is offline   Reply With Quote
