Dumped/Bagged/Slammed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2009, 07:52 PM   #1 (permalink)
Gameroom cash: $109725
View bmbweber's Photo Gallery
Gen6 Dumped/Bagged/Slammed
So i have recently been looking to put air bag suspension on my 08 SE, and i see a few people on here with it (aznhyperracer, SIK CAMRY), and IMO is the best money you can spend on ur car. It just looks to friggin sick. That slammed, hellaflush look.
My problem is that im lost in the subject. I dont know where to begin, i dont know what fits my car, im not sure what is quality, what to even look for in general.
I see kits ranging from at low as around $1k to almost upwards of $5k, but thats about all they tell you. There isnt much DIY/you need these things/this is how to do it, information on the internet: Mostly just sales and pictures.
Im just asking someone with the knowledge/experience im looking for, to possibly write up a just a general forum or something, on just complete air bag suspension. Kindof how there is a complete suspension sticky. What are the best brands? What is needed for a basic complete kit? Pro kit? ect.
It would greatly help out me and some others that are probaly looking for the same information!!
bmbweber is offline   Reply With Quote
Old 12-14-2009, 08:32 PM   #2 (permalink)
JDM420.com
rickdogg's Avatar
iTrader Score: 6 reviews
View rickdogg's Photo Gallery
Stay away from the china made stuff. IMO, I personally like the products manufactured by UAS (Universal air suspension) . They make quality parts that tend to endure more abuse/use than other brands. I've seen people have bags go out on them while driving and valves/compressors that go bad because of poor quality. Suspension is something I prefer not to cheap out on especially if it is something like airbags.
A good quality kit will run you about $2300 with an air tank, valves, lines, fittings, and compressors. For a bit more, you can upgrade with complementary parts that will add convenience to your ownership experience. I personally would also suggest going with an auto leveler such as the "e-level" made by accuair since it really is not much more than purchasing sending units with a digital pressure gauge.
Traditional airbag setups are manually adjusted via the usual switchbox and you are stuck with eyeballing the ride height and guessing. Over time, you can get an idea of how your car feels and rides. However, it is not very accurate or convenient and can be a bit of a nuisance.
Others install digital pressure gauges to monitor pressure in each corner of the car. For instance, they can choose to put 60 psi at all corners and manually compensating for cargo/passengers by putting more air where there is more weight etc.
Dakota digital also makes an auto leveler that monitors airbag pressure and sends air to the airbag if it is lower than what it is preset (programmed) to be set at for you. This particular system reads off of pressure in each bag and does not monitor height. So if the car is not balanced even though the auto leveler reads each corner as being equal at 60 psi at each corner, the car can still not be leveled especially if there are passengers and cargo in the car.
The e-level kit made by accuair utilizes height sensors to monitor actual ride height. This new system is much more accurate than the dakota system that is merely airbag pressure based. All you have to do is preset your desired ride height (level 1, level 2, and level 3) and go. Once you set it, you don't have to manually eyeball the car and adjust accordingly. If the car is too low on one side or corner, the computer will read it and make the adjustment automatically for you. It's as simple as pressing a button on your radio to play your favorite radio station. All you have to do is focus on driving.
The e-level may seem expensive, but the price already includes everything including the height sensors and sending units. If you go with a digital pressure gauge, the sending units are typically sold separately and will add about $130-150 plus another $200 give or take for the gauge to your tab. In my opinion, using that $350+ towards an auto-leveler is a wiser investment.
You can read up on the difference of varying products here:
http://www.jdm420.com/product_info.p...roducts_id=175
http://www.jdm420.com/product_info.p...roducts_id=174
https://www.universalairsuspension.c...33672a76a18004
Also, you will also have to choose from varying fitting/hose sizes. 1/2", 3/8", and 1/4" is the norm. 1/2" will give you the faster drop/raise of the bunch when hitting the switches and will slow down as you go with a smaller diameter. You can also mix it up and go with 1/2" fittings with 3/8" buffers to allow a fast raise and a slower drop.
You also have to decide how your suspension will be setup. Are you going to use bags with coilovers (goes in place of the springs) or are you going to run OEM shocks? I personally think going with coilovers is the better option because they tend to ride a lot better. However, not everyone can upgrade everything at once. You will also have to have brackets made to put the airbags on the suspension.
There is a bit more to look in to, but I am running on 2 hrs of sleep and have finals the next two days. I hope that helps a little bit. You can view my build-up thread for a basic idea on what I did to get an idea of what you prefer:
Rickdogg's Gen 5 Mild Build-Up Thread and background
I actually have spare airbag equipment laying around and can get you started for cheap if you decide to go that route:
-UAS Chrome 5 Gallon Air tank
-SPD Air Valves
-UAS 7 switch switchbox
-& Misc airbag stuff
rickdogg is offline   Reply With Quote
Old 12-15-2009, 11:26 AM   #3 (permalink)
exactly what i was looking for.. thanks you!!
Im going to look into it a little more but if i have any other questions, ill be sure to ask you!
P.S. What could you tell me about air zenith systems?
Old 12-15-2009, 04:11 PM   #4 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
wow, great info.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 12-15-2009, 06:56 PM   #5 (permalink)
JDM420.com
rickdogg's Avatar
You're welcome.
The air zenith stuff is pretty nice stuff as well. Their compressors are a bit more expensive than the Viair units. As a comparison, the Zeniths are ~$200 more than the Viair 480's and will fill up the air tank a lot faster.
Old 12-16-2009, 10:03 AM   #6 (permalink)
SIK CAMRY's Avatar
View SIK CAMRY's Photo Gallery
If you are looking into getting products from AIR ZENITH I am sponcered by them and i could help you out on somethings. Right now the owner is in production on the whole kit before they just specialized in bags and compressors, he will be using my car for the strunts soon for the camry owners that wanna do a bag set up. if you go on the site he has like two or three kits out but its for a charger and i believe 300's he used them to show at SEMA... with his new kit i'm suppose to get 2-3 inches lower then i am now so im expected to lay on lip kit..
SIK CAMRY is offline   Reply With Quote
Old 12-21-2009, 07:44 PM   #7 (permalink)
07 Camry SE V6
View aznhyperracer's Photo Gallery
airruners are good...pretty smooth ride...
^_^iF sPaRkS dOn'T fLy YoU'rE rIdInG tO hIgH ^_^
aznhyperracer is offline   Reply With Quote
