Gen.6 hibeam/lobeam adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2009, 03:39 PM   #1 (permalink)
pandahai's Avatar
View pandahai's Photo Gallery
Hi, i'm trying to get my highbeams adjusted and i've tried searching the forums but oculdnt come up with any luck. I've read on page 76 of this manual
http://www.camrystuff.com/manuals/Ge...E/Lighting.pdf
but couldn't really find the screw where it'll turn my highbeams lower.
i think it's a little too high up.
it says for the 2grfe, but i think its the same as the 2az.
any help would be appreciated. thank you.
2007 Camry CE Super White, 5 Speed Manual
pandahai is offline   Reply With Quote
Old 12-20-2009, 03:41 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Why are you adjusting your highbeam? Its suppose to be higher than you lowbeam. Its set that height for a reason.
Also, its not even a screw...its more of a nut. You use a socket wrench.
CarDomain
Old 12-20-2009, 03:44 PM   #3 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
You cant adjust the high beams on any car. For tge lows its a 10mm nut in the back of the headlight. If u do a search u should be able to find this topic and pics.
Redline_Me is offline   Reply With Quote
Old 12-20-2009, 03:50 PM   #4 (permalink)
pandahai's Avatar
i did some research but i only found out that u can only adjust the headlights, i couldn't find anything on low beams and highbeams. I will look out for it though. thanks a bunch.
Old 12-20-2009, 03:51 PM   #5 (permalink)
Look in ur owners manual.
Old 12-20-2009, 03:55 PM   #6 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
theres a 10mm jig/screw/nut whatever u wanna call it inbetween the low beam and high beam. it raises/lowers the insider reflector/high beam mount. i dont suggest touching it unless both high and low are too high because if you touch that screw both the high beam reflector and low beam projector move.
WrongFitmentCrew#628
Old 12-20-2009, 03:59 PM   #7 (permalink)
pandahai's Avatar
ok thanks a bunch =p
Old 12-21-2009, 12:16 AM   #8 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
I thought when you adjust it, you adjust both at the same time?
(buy my turbo lol)
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 12-21-2009, 01:51 AM   #9 (permalink)
I thought you couldn't move the high beams on any car lol.
(you know i want to, but you also know why i'm afraid to get one)
