Any mechanical insight? (2004 Camry)
Hey all,
So I decided to have another go at trying to fix my rear right power window regulator this morning after an unsuccessful attempt at it yesterday and to my surprise it worked. Of course I did some research on the ToyotaNation forums to see if anyone else was having a similar problem so maybe that made the difference.
The problem I was having was that my rear right power window would not operate between using the rear right power window switch or the driver's side master window panel. It hasn't worked for the last six months and my dad even took it to a mechanic to have it checked out but that only temporarily fixed the problem because it stopped working a week later. Now this morning when I thought to check the parts individually (power window switch, wires, regulator motor) I just tested the rear right switch with the rear left switch and to my amazement it worked! The controls from my driver side master panel worked too so I'm alittle bewildered at why it didn't work for the last six months. As of right now everything works and I put everything back to where it was.
There is also a slight click/tick noise when the rear right window goes all the way down then up and also when the window goes below half way down then up. Any possible mechanical insight would be appreciated since I'm not too well informed on the electrical system on my camry.
Change: its something that was there but isn't anymore, something that should be there but isn't, and something that is there but wasn't there before.
