2004 Camry Power Window Regulator Won't Fit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2009, 02:11 PM   #1 (permalink)
Choman's Avatar
View Choman's Photo Gallery
So I decided to finally take out the power window regulator in my '04 Camry to get the parts number for the power window motor and when I tried to fit the regulator back into the car door, none of the bolt holes line up and I don't know if I should just try to muscle it in or if there is some trick to it.
Any advice would be appreciated since I'm at a lost as to what to do.
Change: its something that was there but isn't anymore, something that should be there but isn't, and something that is there but wasn't there before.
Choman is offline   Reply With Quote
Old 12-26-2009, 03:19 PM   #2 (permalink)
Choman's Avatar
Nevermind about the regulator not lining up with the bolt holes, I figured out after about a hour that the arm had lowered slightly and all that was needed for proper alignment was to move the window glass down alittle.
Sorry for the inconvenience.
