need help with coilovers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2009, 09:06 PM   #1 (permalink)
View built2last08's Photo Gallery
Gen5 need help with coilovers
THese are few i found online.. i wanted to buy one for my camry and i wanted to know which one would u guys buy? and being a college student money is kind of tight.. i m going to try my best to get the one which would give me the most slammed look
and which one would give me a slammed look???
D2 Racing RS Coilover Damper Kit Toyota Camry 2002-2006 $899.00 http://www.hopupracing.com/suspension33.html
Ksport Kontrol Pro Coilover Damper Kit Toyota Camry 2002-2006 $943.95 http://www.raceinspired.com/cs-20-coilovers.aspx
Ksport Kontrol Pro Coilover Damper Kit Toyota Camry 2002-2006 $975.00 http://www.hopupracing.com/kskoprofuadc31.html
D2 Racing RS Coilover Damper Kit Toyota Camry 2002-2006 $997.50 http://www.ilovebodykits.com/product...ota_Camry.html
BC Racing Coilover Damper Kit Toyota Camry 2002-2005 $998.00 http://www.eracingzone.com/BC-Coilov...1-c-30988.html
D2 Racing RS Coilover Damper Kit Toyota Camry 2002-2006 $1,097.95 http://www.raceinspired.com/cs-20-coilovers.aspx
Ksport GT Pro Coilover Damper Kit Toyota Camry 2002-2006 $1,299.95 http://www.raceinspired.com/cs-20-coilovers.aspx
built2last08 is offline   Reply With Quote
Old 12-28-2009, 09:18 PM   #2 (permalink)
scamry's Avatar
Gameroom cash: $194025
View scamry's Photo Gallery
dude...coilovers are adjustable...so you can slam on any of those...
I am on D2 coilovers, and I like them...Be warned though, these are not for making your car ride awesome, they are for stiffening up the suspension for handling and looks... when my car is jacked up my wheels only droop about 1/2 inch, so you can imagine the ride with that little suspension travel..This isn't to say that coils are always going to make your car ride poorly, but they will likely be stiff.
Some people on the boards have had Ksports, and I believe only kasimmm and myself have had the D2s. The BC coils are gaining popularity, and I would have purchased them if I hadn't got a great deal on mine. From the reviews I read they can be set to levels that rival the stock suspension. You may want to try boost and destroy for the BCs, and be sure to call to get quotes, they are usually much better than the listed internet price.
You can adjust the dampening on the coilovers and order custom spring rates if you really want comfort, but with a soft ride you are likely to rub if you are really going to slam your car.
I miss the old days of TN.
scamry is offline   Reply With Quote
Old 12-28-2009, 09:26 PM   #3 (permalink)
thanks man, but i m like a noob at this coilovers stuff, and i m just trying to get the slammed look and i though of going with coilovers instead of springs. and is ur car slammed? like i want it low enough but not to scrub ALOT miner scrub is alright with me.. my brother got is350 07 and he is slammed with bc racing but idk anyone who sells bc racing for toyota camry..
Old 12-28-2009, 09:27 PM   #4 (permalink)
can u post a pic of ur ride like any view so ican see how slammed u r.. that is if u dont mind
Old 12-28-2009, 09:33 PM   #5 (permalink)
scamry's Avatar
like i said. try boost and destroy for the BCs. and you can't be "slammed" without rubbing.
my car is in winter mode, and undergoing some changes right now, so I have no current pics, but this was back in august..I can stand a credit card up against the lowest point of the frame, and I scrape the lowest part of the exhaust a lot. in this pic i was tucking about 1/4 inch of tire front and rear.
Old 12-28-2009, 09:54 PM   #6 (permalink)
NICE car. i love it lol and thanks so much, i m def. going with D2 now. i went to boost and destroy they had BC Racing for 999.. but i think i m going to stick with the D2s cheaper and i love the drop it gave u!.
Old 12-28-2009, 09:59 PM   #7 (permalink)
scamry's Avatar
no no...you can get this drop with any of those coilovers..and if you call them, they will give you better prices..I believe I was quoted at around 850 shipped..
once again these coilovers are adjustable. they can be raised to probably near stock height and lowered beyond drivability. any of these coilovers can slam your car, but i really think that the BCs have better quality..and are what i plan to buy when these die. you should really call around these places to get their bottom dollar quotes. and Ksports and D2s are pretty much the same thing, just different colors and maybe spring rates, while BCs look to be slightly different and perhaps better quality.
I think you should do more research before you buy. Coilovers aren't something you want to buy just on a whim, there is a lot of adjustability to play with...
Old 12-28-2009, 10:32 PM   #8 (permalink)
oh ok, thanks for explaining that man really appreciate it...
Old 12-29-2009, 04:19 PM   #9 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
second BC Racing coilovers... should have gone straight to these instead of lowering springs. try www.importimageracing.com... boost and destroy actually get their coilovers from them. import image racing order direct from BC Racing... but if you get a better price from boost and destroy, then they are a good choice. However, their customer service is not the best, so be wary if you end up with any problems down the line.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 12-29-2009, 04:48 PM   #10 (permalink)
ya, i talked with importimageracing guys, and they said it would be 950 till dec 31st and back to 999 afterwards..
Old 01-03-2010, 06:47 AM   #11 (permalink)
JDM420.com
rickdogg's Avatar
iTrader Score: 6 reviews
View rickdogg's Photo Gallery
When I was in the market for coilovers, I decided to go with BC out of all of the above choices because of the spring rates offered. They ride pretty nice at full soft and can really slam to the ground. I ordered mine from Mike @ doubledownmotorsports.com
Good luck
Rick
rickdogg is offline   Reply With Quote
Old 01-03-2010, 07:11 AM   #12 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
doubledown's website says they went out of business =[ so sad
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 01-03-2010, 06:39 PM   #13 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
hey there, I just finally install partial of my ksport coilover. Just got the front done, I still need to adjust the height. I ran into a problem with a test drive. I am hearing knocking noise. What may cause it??
LoudCamry is offline   Reply With Quote
Old 01-03-2010, 06:59 PM   #14 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
front sway bar, happened it me twice
Old 01-03-2010, 07:01 PM   #15 (permalink)
LoudCamry's Avatar
front sway bar??? how to fix it??
