2azfe connecting rod limits... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2009, 08:34 AM   #1 (permalink)
View 88uu898's Photo Gallery
hi people, anyone know at what hp range are the stock 2azfe rods not safe? any turbo guys with stock connecting rods? anyone broken a stock rod?
88uu898 is offline   Reply With Quote
Old 12-30-2009, 09:09 AM   #2 (permalink)
Old 01-04-2010, 04:14 AM   #3 (permalink)
anyone?
05 Camry 5sp.
Custom turbo kit
Old 01-04-2010, 04:44 AM   #4 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
There aren't many guys who have turbocharged a 2AZ and few that have seem to be low boost setups on unopened engines. They're a relatively high compression engine, you would need to deal with that before making serious power on one of these.
Generally speaking though Toyota seem to quite heavily over-engineer all their engines.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
Old 01-04-2010, 07:59 AM   #5 (permalink)
Asteroid's Avatar
Yep high compression turbo conversions are super sensitive to the tune, it's the nature of the beast.
If you intend on boosting it hard I'd be inclined to crack it open and either play with the combustion chambers and/ or the pistons. Also you can suss out the rods to see if they're up to the task, but I'd guess they are.
Old 01-04-2010, 03:13 PM   #6 (permalink)
thanks for the feedback guys
05 Camry 5sp.
Custom turbo kit
Old 01-09-2010, 11:23 AM   #7 (permalink)
View AlmightyCamry777's Photo Gallery
Do you want an engine that will go for 200,000 miles or is this not a concern? If you're going for long haul, you probably need new forged connecting rods (the stock ones are cast) and better pistons. The engine is all aluminum with steel sleeves, so it has some built-in limits unless you're not concerned about putting a rod through the engine block.
4 bolt mains would be ideal and somebody somewhere probably makes a block like this, but probably not too practical just on cost. The stock crankshaft is pretty strong and might take the added power but your lubrication had better be first-class. The stock pistons and rings may be problematic if you run the engine so the turbo boosts alot, since they're not designed for a turbo. You'd definitely want a seperate small oil reservoir for the turbo that feeds it oil if you shut off the engine right after a fast run - or else just remember to idle the engine for a couple minutes after turbo engagement before shutting the engine off.
AlmightyCamry777 is offline   Reply With Quote
Old 01-10-2010, 04:51 AM   #8 (permalink)
Ive decided to go with K1 rods. Ive already bought wiseco pistons and arp head studs. Ive been running this turbo on the stock 2azfe motor for over 2 years now... want a lil more power... power goal is 400whp, nothing too crazy, because is a daily...
05 Camry 5sp.
Custom turbo kit
