08 Camry SE headlight bulb burned - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2010, 01:59 AM   #1 (permalink)
View PurpleDrank39's Photo Gallery
I replaced the headlight bulb this afternoon. My wife called complaining the right side bulb was burned and melted the housing. The left side started to burn, but she made it home before it melted anything. Not sure why it burned. I didn't even touched the bulb lens at all. And I am not certain why it burned at all. But noticed 2 rubber seals on both bulbs which I thought was strange to have on vehicles. Any reason why it did this? This is the first time this has ever happened.
PurpleDrank39 is offline   Reply With Quote
Old 01-01-2010, 02:21 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $999364
View humanoid's Photo Gallery
What rubber seals are you referring to? Any pics of what burned?
humanoid is offline   Reply With Quote
Old 01-01-2010, 09:08 AM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
I think he is talking of the rubber seal on H11 bulb. Used to keep moisture out of the headlight cover.
Did u make any change? If not and still using the old halogen bulb than I guess the dealer can do something.
workerant is offline   Reply With Quote
Old 01-01-2010, 12:31 PM   #4 (permalink)
Paul_09WhiteV6
Gameroom cash: $592785
iTrader Score: 10 reviews
View Pawel062's Photo Gallery
hmm interesting that the burner. wonder what happened. hids in there or higher watt bulbs? we need more pics.
WrongFitmentCrew#628
Old 01-01-2010, 07:15 PM   #5 (permalink)
Yes it's the H11 rubber seal. It has two of them. One already attached to the headlight and the other around the bulb it self. Yes I have the original bulbs which they will have to use for the mean time.
Well the dealer has to replace it. I bought it with some kind of warranty where I can drop it off at Toyota and get it fixed. The headlights has to be replaced with a new one. The old one (Passenger side light) You can't put it in and twist. It burnt the housing so you can't secure at all.
I still wanted to know what cause it to burn the bulb? It's a mystery!
Old 01-02-2010, 12:04 AM   #6 (permalink)
Originally Posted by djkor View Post
What I'm trying to understand is what you mean by two seals. H11 bulbs should only have one seal on them. It would be good if you could supply a photo of what you are referring to because this could have been the cause of your problem.
I'll post pics later. One seal is around where the bulb fits into the grooves and you turn it. The second on was around the stock bulb.
Old 01-02-2010, 12:29 AM   #7 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
what kind of bulb did you use as a replacement ...
this is common among aftermarket bulbs ...
CamrySExxx is offline   Reply With Quote
Old 01-02-2010, 10:13 AM   #8 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
The diagnosis is only as good as the problem description which is almost non-existent.......
Old 01-02-2010, 11:50 AM   #9 (permalink)
Aftermarket. The question still stands, what would cause it to burn? This is the first time a bulb burned when I changed bulbs. I always change the bulbs when getting a car. The standard bulbs the dealers put is garbage!
Old 01-02-2010, 01:15 PM   #10 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
Factory installed bulbs don't typically melt stuff
That's pretty good in my book.
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 01-02-2010, 01:15 PM   #11 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $150432
View Yazovets's Photo Gallery
Chances are you bought aftermarket bulbs which, despite being advertised as being 55W are actually something much higher.
There are popular Nokya H11 yellow fog bulbs on eBay but when you buy those, they're actually stamped 85W and not 55W.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 01-03-2010, 12:42 PM   #12 (permalink)
They weren't factory bulbs. They were aftermarket. I had a theory and that theory is that if the bulb touched while I was trying to insert and lock it in, it may had been the reason why it burned. The sad part is that Toyota wanted me to replace the whole headlight assy both left and right at 275.00 apiece. It was at 308 a piece, but since the platinum warranty doesn't cover changing bulbs I did my self, I had to pay out of pocket. The finacial guy was trying to get me hooked up and this is what service and parts can do for the time being. But I researched and found that if I order the headlight assy myself, I save alot of money around over 100 bucks. Genuine toyota parts. I found the OE Replacement cheaper, but not sure if I buy those, will Toyota be willing to install them into the car next week? Since it's not a toyota genuine part, they may not install it. Not too sure. If anybody has had success buying OE Replacement headlight assy and toyota install them, let me know.
Old 01-03-2010, 12:55 PM   #13 (permalink)
Paul_09WhiteV6
best thing is to buy toyota oems. if the bulbs touched something then they wouldnt burn like that. maybe if u touched them but not if they touched something else. my 85122 bulbs touch something all the time when i insert them but never had problems with them. it's probably high wattage bulbs that u used. btw u can also change the headlights yourself. if you dont mind then send me the melted assemblies after they are taken out. can use them for retrofit parts and also i'll tell you most likely what happened.
Old 01-03-2010, 02:25 PM   #14 (permalink)
what brand bulbs ... ?
you need to provide more info.
and according to your theory, you installed the bulb while the lights were on?
Old 01-03-2010, 08:17 PM   #15 (permalink)
The brand is X-Rated Polar White bulbs. And as for the theory, I never turn the car on while changing bulbs. I feel safer leaving the car off and change the bulbs. Then start the car or turn the lights on and test to see if lights come on.
