I thought at least the (slightly) older U-series still have manual valves for non-forward gears. The forward gears in just about all transmissions these days are computer controlled. Shift-by-Wire transmissions have been used on trucks for ages for obvious reasons, so that's nothing new. However, its application in small automobiles was the first when BMW introduced its Shift-by-Wire transmission.
But at least you can still shift into neutral if (heaven forbid) the ECU goes haywire, as a lawsuit claimed, and the engine accelerates out of control.
However, if the computer fails and you can't shift into neutral that would be another story.
Originally Posted by BuckeyeGuy
A couple of days ago I was traveling down the highway. I noticed something that was in the passenger floor that I needed to move. Without thinking, I unbuckled, and then leaned over to get it (I know not smart). This is where it gets a little fuzzy because I scared myself a little. When I moved the item, and went to press on the gas pedel the engine just reved. I thought "Oh crap" I'm in netural. So I shifted down once and pressed on the gas again and still the engin reved. From what I RECALL, I looked up at the dash saw it in netural and then shifted down again into drive and all was good.
So here's the question. I now know that I must have bent over so much that I shifted the gears. Good to know NEVER to lean over like that again. Is it possible that I had shifted into reverse, but since I was traveling at highway speeds the transmission knew not to go into reverse?? I've replayed what happened in my mind lots of times and from what I can remember, there were two rev ups and two shifts. It's possible there was a rev, my mind thinking "O crap" another rev then a shift from N into D. Thoughts?
