90000 mile service - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2010, 09:10 PM   #1 (permalink)
View wjd03's Photo Gallery
90000 mile service
hey all, got a 05 Camry with 90k on it and its ready for service. It is my wifes car and about all I do to it is change oil, rotate tires etc., the big stuff gets done at the shop.She called today for Timing belt replacement and shop said she has a timimg chain. Its a 4cyl LE 2.4 or 2.6L. Whats the deal? What service is required at 90k?
Thanks for the info,
wjd03 is offline   Reply With Quote
Old 01-06-2010, 09:30 PM   #2 (permalink)
View Axxis8203's Photo Gallery
at 90k all i'd do is an oil change. the timing chain will probably outlast the car, and has no scheduled replacement interval. Change out the coolant and spark plugs at 100k. And i hope you've been doing ATF drain and fills every 30k.
Wise Men STILL seek Him!
Axxis8203 is offline   Reply With Quote
Old 01-06-2010, 09:34 PM   #3 (permalink)
thyanks aaxis yea she gets it done there, but I think I'll do it this time. Its an automatic, what type ATF to use?
Again, thanks for the reply
Old 01-06-2010, 09:38 PM   #4 (permalink)
as far as the ATF goes, only use Toyota ATF and the type specifically called for in the manual. i'm not 100% sure but i think that tranny uses Toyo type T-IV, but toyotas' newest fluid is ATF -WS and it may be backward compatible with your tranny. best bet is to call the local stealer to verify.
Old 01-06-2010, 09:38 PM   #5 (permalink)
LoudCamry's Avatar
Gameroom cash: $229927
View LoudCamry's Photo Gallery
My sister got her water pump , cam seal, vavle cover seal, spark plug replace around 90k.
LoudCamry is offline   Reply With Quote
