Originally Posted by carlo$
3 mos max for oil, plugs 100k .
I'm with Carlos, if you are using dino (non-synthetic) oil, 3 months is probably ideal if you intend to keep the car a long time. Not only does moisture collect inside the engine when it is idle. the oil begins to oxidize the moment you pour it out of the bottle which means the additives get weaker over time just from being exposed to the air.
If it doesn't get 3,000 miles i wouldn't change the filter every time but every other time. the small amount of oil left in the filter would just be mixed with the new stuff and nothing to worry about.
you ask do we think you should get rid of it, so i have to ask, why get rid of a good running car? You didn't mention any problems so my answer would be no!
