fuel problems, where to start? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2010, 05:13 PM   #1 (permalink)
View rajvoSa's Photo Gallery
hey guys!
Been reading this forum a lot, solved few issues thanks to other posters experiences. Now i have a problem that i cant diagnose.
My car is 2002 camry, 4cyl, a/t, 105k miles. It starts fine, idles fine. When i put in in gear and try to move it acts funny like it has no gas, it would twich until it reaches 2000 rpms, than it would be fine from there on. I almost caused an accident getting on the highway, i stepped on the gas pedal to join the traffic and car just wouldnt move until i actually let it roll on its own to a certain speed and then accelarate gently. It might also have this cut off at higher speeds but its not that noticable since car is already rolling. My obd2 scanner shows no dtc's in memory, it has green light/shows that car is emission ready like everything is totally fine. Since its not throwing cel i think it might be fuel related. Where to start checking, any suggestions? Any common fuel related problems with our cars?
thanks in advance!
rajvoSa is offline   Reply With Quote
Old 01-09-2010, 06:40 PM   #2 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
sounds like a bad torque converter.
Old 01-09-2010, 06:56 PM   #3 (permalink)
thanks for reply!
Wouldn't bad converter give me a CEL and code in 700's?
Old 01-09-2010, 08:45 PM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
I experienced a similar problem on my V6 '07. 2 error codes did pop up on the reader.
P0022 -- "A" Camshaft Position timing over-retarded (Bank 2)
P0354 -- Ignition coil D Primary Malfunction
The car felt like it was choking at random times, especially when accelerating or going slow. I know your car is not the same, just saying the problem u describe was similar.
workerant is offline   Reply With Quote
Old 01-09-2010, 09:03 PM   #5 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352560
View gdanaher's Photo Gallery
Start by dumping a couple bottles of carb cleaner in the gas. Cheap and can't hurt. Might not fix it, but someone at the dealer is going to want to clean the fuel system for you.
gdanaher is offline   Reply With Quote
Old 01-10-2010, 08:00 AM   #6 (permalink)
@gdanaher, u r right, will do that today.
@workerant, yes, symptoms are the same. I wish (as ridicioulos as it may sound) i get CEL so that i can follow it from there. Right now obd shows that everything is perfectly fine and its not, this car is not safe to drive at all.
thank u both
Old 01-11-2010, 02:33 PM   #7 (permalink)
Ok, added 2 bottles of carb cleaner, no changes. Cleaned TB (wasnt bad anyway), no changes. Still no CEL on.
When driving in reverse car is not choking like when going forward. I dont know if that helps any diagnostics but I thought i should mention it.
I was wondering did anyone here ever replaced a transmission without having any codes (CEL) on? What are the chances of mechanical parts (hence no codes) failing inside?
We have 3 toyotas in the house, 2 hybrids and this one, they have been nothing but nightmares lately. I thought our cars were suppose to be most reliable on the market?!?
Old 01-11-2010, 03:15 PM   #8 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
It still might be your transmission since driving in reverse produces no problems. How about you fluid.
If this is a fuel related issue you need special tools to test it out.
Good luck,
Sa,
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Old 01-11-2010, 03:35 PM   #9 (permalink)
thanks for your input
Fluid level is fine, its red and doesnt smell bad/burnt.
As far as checking fuel pressure it would be very hard to find anything wrong because I am only having problems when driving. When car is idling it runs great, there is no choking and if i step on the gas i can send it to redline without cuting off. So I would need to check fuel pressure when driving which is impossible. I dont know if I am making sense?!
Old 01-12-2010, 09:01 PM   #10 (permalink)
View coontai's Photo Gallery
does it rev/high idle in park okay?
coontai is offline   Reply With Quote
Old 01-12-2010, 09:10 PM   #11 (permalink)
In park it idles just fine, little over 700rpm's, no skip.
Old 01-12-2010, 09:46 PM   #12 (permalink)
but when you depress the accelerator pedal and rev it is the engine responding appropriatly?
Old 01-12-2010, 10:02 PM   #13 (permalink)
in park -yes, it responds normally.
Old 01-12-2010, 11:57 PM   #14 (permalink)
that sucks. good luck
Old 01-13-2010, 04:10 PM   #15 (permalink)
View AlmightyCamry777's Photo Gallery
The engine may be misfiring under a load, which usually indicates an ignition problem. Have the coil packs tested, one or more could be weak and it might not even throw a code. Also when was the last time you changed your spark plugs -
AlmightyCamry777 is offline   Reply With Quote
