Help with Door Lock Programming
Hi All,
I've looked everywhere I can think of and searched all over but I can't seem to find the correct sequence to use to change the door lock programming so my Camry won't lock and unlock the doors when I shift in and out of Park. I'm ok with the doors locking when I reach 12 MPH but I don't want all the doors to lock and unlock based on gear. This is what I tried that didn't work found in another thread;
Step 1 Set the dome light control knob to the "door" position.
Step 2 Be sure the shift lever is in "Park" and close all doors.
Step 3 Insert the ignition key and turn it to the "On" position.
Step 4 Within five seconds after the key is turned "On," push and hold the
driver's side power door lock switch for about five seconds.
Step 5 The dome light will flash to indicate the mode that is active. One
flash indicates mode 1, two flashes mode 2, three flashes mode 3, and four
flashes mode 4. To change to the mode, push the lock switch until the light
flashes to indicate that the desired mode is active.
2010 Camry LE w/ EX and QA
Build Date: 12/09
Covercraft Full Mask/Husky Trunk Liner/
Toyota Mud Flaps/iPhone 3GS Bluetooth
