Hi,
Does anyone have experience in fixing the headlight washer of a 2000 Camry (gen. 5)? The following is the situation: there is water in the container, pipes are OK, pump is OK, when the button is pushed, it goes, BUT! The water - instead of coming out through the nozzles - sprays into the engine compartment...
I disassembled the whole thing and found that there's a special part right before the nozzle: a little plastic right-angled pipe, which has a spring powered rubber ventil inside and a hole on the back. Now the water comes out through that hole.
I cleaned out these pieces, but pretty much no dirt came out. My assumption is that those holes are meant to suck in air in order to make the water spray dissolve better. However, the spring-powered ventiles don't allow the water to go towards the nozzles, but through the holes towards the engine compartment!
Any ideas on how this thing works and how to get it back to normal, please let me know
Thanks!
