2002 Camry SE Shifter and HVAC Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2010, 11:19 AM   #1 (permalink)
View Tharmagon's Photo Gallery
My wife has a 2002 Camry SE 4 cylinder. The indicator lights on the shift lever started going out. If we tapped the console they would come on again for a while. But now they stay off n o matter how much we tap it. I thought that is just the bulb or a fuse issue. But today two of the background lights on the HVAC console have gone out as well. Are these issues related or are the bulbs just dieing at the same time? I wondered if there was some sort of regulator or something that is not supply the correct power?
Also at the same time as the shifter lights going out the check engine light came on. Then when we tapped the lights and they came on the check engine light went out. Is the check engine light linked to the shifter lights?
Tharmagon is offline   Reply With Quote
Old 05-13-2010, 08:31 AM   #2 (permalink)
olympicgold's Avatar
View olympicgold's Photo Gallery
So does anyone know how to change shifter bulb in Gen 5. LE/XLE ?? I cannot find DIY or instructions whatsoever
olympicgold is offline   Reply With Quote
Old 05-13-2010, 01:08 PM   #3 (permalink)
View cardoc56's Photo Gallery
Hello The Bulbs Are Easy Access. The Concole & Controll Panel Will Pry-up With A Flat Tip Screw Driver --cardoc56
cardoc56 is offline   Reply With Quote
