new tires+alignment=drift to the right?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2010, 12:59 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
Gen5 new tires+alignment=drift to the right??
hey all,
after getting my new tires mounted and balanced, i had my car aligned. This was all at firestone where i have a lifetime alignment. Prior to everything being installed, the car drove perfectly straight. Now, the car drifts to the right if i do not hold the wheel. It isnt so severe that i have to constantly correct it, but it doesnt seem normal. I took it back after i felt it drifting to the right so the tech took my car for a test drive with me in the pass. He said he didnt feel anything out of the ordinary and i told him that if you take your hands off the wheel, you will see how it drifts right. He asked if i normally drive with no hands . I took his word for it and have been driving with it for a week or so to see if i can live with it but I just cant. I want to suspect it is the alignment that is the problem and not the tires, so can you all take a look at my alignment specs and see if they seem right?
L FRONT R
camber -0.9 -1.1
caster 2.4 2.4
toe 0.01 0.03
L REAR R
camber -1.4 -1.5
toe 0.20 0.14
thrust angle: 0.03
MrSo0h0o is offline   Reply With Quote
Old 01-15-2010, 01:06 PM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
tire pressure?
Redline_Me is offline   Reply With Quote
Old 01-15-2010, 01:13 PM   #3 (permalink)
MrSo0h0o's Avatar
Originally Posted by Redline_Me View Post
tire pressure?
tire pressure is equal on all 4 tires
Old 01-15-2010, 01:19 PM   #4 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
R they radial tires? If so, check the direction.. who knows, he might goof when install the tires.
workerant is offline   Reply With Quote
Old 01-15-2010, 01:25 PM   #5 (permalink)
MrSo0h0o's Avatar
these are the tires: http://www.conti-online.com/generato...en;tabNr=.html
they are all mounted properly
Old 01-15-2010, 01:38 PM   #6 (permalink)
"Circle of trust"
View catric69's Photo Gallery
If the vehicle veers slightly to the right, that would seem normal. The car is going to follow the crown of the road.
catric69 is offline   Reply With Quote
Old 01-15-2010, 01:40 PM   #7 (permalink)
Oh yes.. DWS... it's radial tires. Read on the side of the tire, it says.... hmm.. I forgot...... something like "Outside" ..... U can't see it now but the other side of that will say "inside".
Just double check see if he installed it properly.
I had to double check http://en.wikipedia.org/wiki/Radial_tire and here it called "steel-belted radial".
When you rotate the tires, your only pattern choice is front to back. No crossing.... radial thing.
Old 01-15-2010, 04:33 PM   #8 (permalink)
MrSo0h0o's Avatar
i tested the car on a flat parking lot and it still drifts to the right a bit.
yea i will double check the inside/outside on the tires but based on the tread pattern, im pretty sure they are correct.
Old 01-15-2010, 05:21 PM   #9 (permalink)
Gameroom cash: $304255
Switch the 2 front tires with each other as a test. if the car now pulls left, you have what is known as a radial pull in the tire now on the left front. The only remedy is to replace that tire. If so, I hope you bought the tires at Firestone, so it will be their headache.
Mike
Old 01-15-2010, 07:54 PM   #10 (permalink)
2008 SE V6
thoots's Avatar
View thoots's Photo Gallery
Mike
You bet. And if it doesn't pull left.....
Really, most of "pulling to the right" is due to being on the right side of the crown on the road. Really, pure and simple. Some tires may be more or less affected by the crown effect, and/or perhaps it can be dialed out with the kind of painstakingly precise alignment work that most shops simply won't do.
So.... One thing you can do is just put 1 psi more into the right-side tires than the lefts. Or perhaps less than that -- try .5 psi, and if that doesn't quite get the job done, try 1 psi. This can really help even out the pull on your steering wheel in most situations -- give it a shot, if you're game.
thoots
thoots is offline   Reply With Quote
Old 01-15-2010, 08:17 PM   #11 (permalink)
Gameroom cash: $169021
View Dave-o's Photo Gallery
I had such a headache when I ordered my winter tires.
I found out my pulling problem was caused by my new tires which needed to be rebalanced again.
The steering wheel vibrated violently when I drove above 45mph... if your steering wheel doesn't show vibration or some crazy jerking, it won't be your tires... I can say that much...
After rebalancing my winter tires, there was no more vibration and hard pulling BUT there was a slight pull to the right side.
Only problem my uncle suggested to me ( we checked my alignment too, its perfect), is torque pull. He says naturally the car could pull to a side when you add gas or coast 10mph+
Are the new Continental tires 215/60/16?
Dave-o is offline   Reply With Quote
Old 01-15-2010, 10:57 PM   #12 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Rotate the tires left-to-right. If you still drift to the right, and no change had been made to the mechanical before/after the new tires/alignment, then it's the recent alignment.
Many shops have problems center the steering wheel. Maybe another Firestone nearby?
Old 01-18-2010, 09:06 AM   #13 (permalink)
I also bought the same tires, I'll let you know if it does the same on mine.
Old 01-19-2010, 11:17 AM   #14 (permalink)
MrSo0h0o's Avatar
ok so i switched the two front tires to see if it was radial pull. when i took it out on the road, i had the same pull to the right.
i brought it back to the firestone to have it realigned and here are my alignment numbers:
L FRONT R
camber -0.8 -1.1
caster 3.0 2.7
toe -0.22 0.23
L REAR R
camber -1.3 -1.6
toe 0.15 -0.04
thrust angle: 0.10
From what i can tell from before and after numbers, they changed the front toe a lot and the rear right toe.. It doesnt drift to the right nearly as much anymore and the steering wheel stays fairly straight.
Should the toe values be so opposite? i told them it was pulling to the right and i kinda feel like they just compensated for that by putting toe in on the front left and toe out on the front right?
Old 01-19-2010, 02:43 PM   #15 (permalink)
Too much toe will eat right through your tires.
My back tires are bald after 3 months, and i think its because my toe is way off.
