Michelin Primacy MXV4 Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2010, 04:22 PM   #1 (permalink)
270hp = Happy Foot
Gameroom cash: $396245
View aznlunatic206's Photo Gallery
Hey guys i recently checked my tire air pressure and it was at 35psi, is that fine? I have Michelin Primacy MXV4 215/50R17 on my car. Specs says max of 50psi and i searched around on google and people would run them as high as 40psi. would 40psi be recommended over 35psi? tires where measured when cold.
aznlunatic206 is offline   Reply With Quote
Old 01-20-2010, 06:06 PM   #2 (permalink)
View keith91's Photo Gallery
I don't have these tires on my Camry that I just got, but I had them on my old car. I always ran them at 38-40 psi since I liked the way they road at the higher psi and I had really, really good tire wear at that higher pressure as well. I intend to put these on my Camry when I replace the tires and will run them around 40 again.
Good luck,
Kg
keith91 is offline   Reply With Quote
Old 01-20-2010, 06:11 PM   #3 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
It's all a matter of preference. Some prefer the factory recommended soft 29-30 PSI on some cars but I keep my cars at 34 PSI. Good balance of comfort and handling.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 01-20-2010, 11:49 PM   #4 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
why not follow the recommended psi?
also remember can can unevenly wear your tires if the psi is too high ...
CamrySExxx is offline   Reply With Quote
Old 01-21-2010, 01:53 AM   #5 (permalink)
270hp = Happy Foot
i called Michelin and they recommended 33psi, i have them at 35 cold. i drove on them at 40psi and the ride was a bit rough, so i went to 35, max psi on the tire was 50psi. the recommended tire pressure 29-30psi a standard for all tires no matter how big or small?
Old 01-21-2010, 08:49 AM   #6 (permalink)
View Shelbrain's Photo Gallery
Recommended PSI is 35 on my 07 Sienna and 32 on my 08 Camry. I run the Sienna at 35-37 and the Camry at 35.
Shelbrain is offline   Reply With Quote
Old 01-21-2010, 01:23 PM   #7 (permalink)
The factory recommended PSI is geared for a soft ride. I've always run my tires at 34 PSI and there have been no problems. All of my friends do the same on my recommendation with no problems either. It's really just a matter of personal preference as long as you're not being dumb and running it at 45 or 50 PSI.
moving forward
Old 01-22-2010, 06:36 PM   #8 (permalink)
View hossmaster's Photo Gallery
i found 32 is a good psi. did you notice that the newest version of that tire has better tread characteristics but a shorter life span.?
hossmaster is offline   Reply With Quote
Old 01-23-2010, 03:23 AM   #9 (permalink)
270hp = Happy Foot
i dont think so? they have a new mxv4?
