CEL and codes P0174 P0171 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2010, 03:06 PM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
Gen6 CEL and codes P0174 P0171
Hey guys, I just did an oil change at my vocational school on my grandpas car, 2008 LE V6. On the way back it threw a CEL. Codes are listed in the title. Now googling those codes i found info on other car manufacturers i.e ford, dodge etc.. But i found nothing in regards to a gen 6 camry. It seems like this code has somthing to do with the engine running lean. Bank 1 and bank 2. What could cause these codes and what could be a posssible remedy. P0174 and P0171 were both pending and setting a cel dont know if maybe they were pending before i did the oilchange.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
Old 01-21-2010, 03:16 PM   #2 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $337725
View glenn14's Photo Gallery
Originally Posted by BlackCamSe View Post
Hey guys, I just did an oil change at my vocational school on my grandpas car, 2008 LE V6. On the way back it threw a CEL. Codes are listed in the title. Now googling those codes i found info on other car manufacturers i.e ford, dodge etc.. But i found nothing in regards to a gen 6 camry. It seems like this code has somthing to do with the system running lean. Bank 1 and bank 2. What could cause these codes and what could be a posssible remedy. P0174 and P0171 were both pending and setting a cel dont know if maybe they were pending before i did the oilchange.
Check out this thread.. this may help.
HELP ME, 2002 Highlander 4WD V6 ENGINE
Or you could clear the codes and see if they come back again.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 01-21-2010, 03:40 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
Glenn
yea that was exactly what i did. Maybe the car just wasent used to be driven hard like i was doing. If they come back ill proobably take it back to school and diagnose it there.
EDIT: Just got the call from my grandpa, the light came back on...going to bring it to the dealer tomarrow
Old 01-21-2010, 06:40 PM   #4 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
now that i think about it. Could oil from a K&N air filter clog the MAF and cause a lean mixture?
Old 01-21-2010, 08:21 PM   #5 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
No time to read your Factory Service Manual?????????????
Old 01-21-2010, 08:32 PM   #6 (permalink)
View tomtom25's Photo Gallery
a vacuum leak can make it run to lean. It's either for a lean code or your o2 sensor cant think right off hand but I really think it is for a to lean code.
tomtom25 is offline   Reply With Quote
Old 01-21-2010, 08:42 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
i don't have money to waste on a factory service manual....i need gas money. Buying something that ill use 2, maybe 3 times is a waste to me. IF your going to help contribute to the thread then be my guest and post. Otherwise kindly shut your mouth.
Old 01-21-2010, 08:45 PM   #8 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
Originally Posted by tomtom25 View Post
a vacuum leak can make it run to lean. It's either for a lean code or your O sensor cant think right off hand but I really think it is for a to lean code.
i know what the codes are. System lean bank 1 and bank 2..i didn't hear any hissing of any kind, and contrary to my findings the car has no loss of power or any type of trouble idling.
Old 01-24-2010, 11:38 PM   #9 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Turns out that it was one of the assholes in my school that pulled a vaccum line and thats what made it throw a code. It was the small one from the intake manifold into the side of the air filter box. Pluged it in and the light went right off.
Old 01-24-2010, 11:54 PM   #10 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
^thats good then, easy fix for a code man
Old 01-25-2010, 08:39 PM   #11 (permalink)
glad it was a easy fix man.
Old 04-19-2012, 03:24 PM   #12 (permalink)
01 solara v6
View jaybro86's Photo Gallery
I put cold air in and I haven same error but the hose that can with air intake is 10 km and is to big for vac hose and vacation house is to small for intake help?????
jaybro86 is offline   Reply With Quote
Old 04-19-2012, 03:25 PM   #13 (permalink)
01 solara v6
10mm sorry
Old 04-19-2012, 04:12 PM   #14 (permalink)
gator1939's Avatar
Gameroom cash: $244835
View gator1939's Photo Gallery
Yep, asking others to solve your problems is always cheaper than learning to read and solve your own. All I can say is that I'm glad I didn't go through life depending on others and glad I taught my kids to do the same.
gator1939
2B1ASK1
gator1939 is online now   Reply With Quote
Old 04-19-2012, 05:20 PM   #15 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
gator1939
you do realize that this thread is over 2 years old correct?
