The thing with the stock jbl amp is it runs at around 2 ohms....you can check this by getting a multimeter and testing it but im pretty sure it was a 2 ohm load last time i checked....the thing is with mostly all after market speakers you will find them running at 4 ohms but they do make a 2ohm speaker but its more than likey not in the brand that you want....also whatever it said on the sticker i think 440 watts is peak and not RMS....so more than likely if you do find 2 ohm speakers your just going to be running loww wattage to them...i personally upgraded everything and i just bought a new 4 channel and 2 sets of components....
CAR AUDIO REBUILD IN PROGRESS...2007 TOYOTA CAMRY SE I4.......
