Hi everybody,
I tried to post in previous thread, but unfortunately topic was closed. Hope moderators won't bounce this one.
SEAT BELT BUZZER ON/OFF SETTING
The seat belt buzzer ON/OF setting, which is a setting of the buzzer function of the combination meter, can disable the driver and front passenger side seat belt buzzers.
NOTICE:
- These buzzers should be on for safe driving.
- When either the battery cable or the combination meter connector is disconnected, these buzzers are set on (enabled)
- Odometer returns to 0 after starting this procedure, although it's not displayed.
HINT:
"b-OFF" indicates that the buzzer is OFF. "b-ON" - the buzzer is ON. The seat belt buzzer ON/OFF setting will be finished (the odometer will display "ODO") if the ODO/TRIP switch is not operated for 10 seconds or more. In this case, perform step 11 to check that the buzzer ON/OFF setting is complete. If it's not complete, start from step 1 again.
DRIVER AND FRONT PASSENGER SIDE
- Turn the ignition switch on (IG)
- Press the ODO/TRIP switch until the odometer displays "ODO"
- Ignition switch off
- Press the ODO/TRIP switch immediately(within 6 seconds) and hold it down for 10 seconds or more
- Continue holding down the ODO/TRIP switch and fasten the driver side seat belt
- Check that the odometer displays either "b-ON" or "b-OFF"
- Press the ODO/TRIP switch to change the display to "b-OFF"
- Check that no buzzer sounds
Same procedure applies to passenger side. Sit in the front passenger seat and repeat 11 steps.
I didn't do it for my 07 SE and probably won't do. But everybody welcome to try and share their thoughts.
