Hissing noise from my 07 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2010, 11:39 PM   #1 (permalink)
bawazir_chicago's Avatar
View bawazir_chicago's Photo Gallery
gen 7 Hissing noise from my 07 camry
Every time i press on the brakes or move the streeing wheel lightly i hear a hissing noise? the hissing noise coming from under the streeing wheel.
can you guys help me find out what it is?
I took it to the dealer he said is normal ???!!
It's hard to be humble when you're from Chicago.
link:http://www.cardomain.com/ride/3820102
bawazir_chicago is offline   Reply With Quote
Old 02-03-2010, 02:07 AM   #2 (permalink)
I got a kangaroo as a pet
private_number's Avatar
Gameroom cash: $342822
View private_number's Photo Gallery
Did you get a sound system installed recently? One of my mates got his done and straight after noticed something similar.
private_number is offline   Reply With Quote
Old 02-03-2010, 02:17 AM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3627850
Have you checked the level of fluid in your power steering system? Could be a problem with the power steering pump. That's where I'd start.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 02-03-2010, 02:58 AM   #4 (permalink)
ilikecamrys
Cking's Avatar
Gameroom cash: $532185
iTrader Score: 17 reviews
View Cking's Photo Gallery
@Dealer, but did you do anything to the car recently?
Like maybe install Fujita Cold Air Intake cause I hear a hiss all the time :P
2k8 V6 Camry SE\\55w6000kHID||3000kfogs||Work Emotion CR-ULTIMATES
||BuddyClub Coilovers||SPC Camber Bolts||TRD Dual Catback Exhaust
||Megan FrontTowerStrutBar||StopTech Slotted Rotors||PosiQuiet Pads
||Fujita ColdAirIntake||My thread!||TN lanyards!||
Cking is online now   Reply With Quote
Old 02-03-2010, 08:46 PM   #5 (permalink)
any more feed back
Old 02-04-2010, 12:34 AM   #6 (permalink)
2007 Camry SE V6
Gameroom cash: $132790
View thrawnis's Photo Gallery
This is actually a known issue and is covered by a TSB. My car has this problem also and basically makes this noise any time I am braking at low speeds. It is something related to a brake pump or valve that is located within the dash immediately to the left and below the steering column.
Someone else posted the TSB info about 3-6 months ago, I think, but I couldn't find the post.
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is online now   Reply With Quote
Old 02-06-2010, 08:35 PM   #7 (permalink)
Did u fix it??
would someone in here knows where this thread ?>??
Old 02-06-2010, 11:08 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There was a TSB (ST002-07) on ticking noises because of poor lubrication of the steering column intermediate shaft. Not sure about brake/steering related hissing. Sounds like some kind of pump problem as mentioned.
So did you get the pedal recalled?
The Following User Says Thank You to JohnGD For This Useful Post:
bawazir_chicago (02-18-2010)
