Camry hesitates - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2010, 08:50 AM   #1 (permalink)
View 2007cam's Photo Gallery
Camry hesitates
Hi there ,
I was on Highway speed approx 70 MPH and had following problem
Car had sudden power loss just for a second and sudden jump very minor in nature , and had this occurence for a while but wud not stall.
Then @ stop light I see the RPM indicator just below 1 not idling going to stall but woudn't stall. Thease conditions would happen at very cold or warm
temperature's.
Suspect following When I did my Rust proofing did something contaminate the
ignitor , I did change fuel grades but did not correct the issue.
When I took it to Toyota when diagnostic check done , nothing comes up.
Any ideas please update ....
Many thanks and regards
2007cam is offline   Reply With Quote
Old 02-07-2010, 09:14 AM   #2 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
Change ur air filter and put some fuel injector cleaner in the tank next time u fill up. See if that helps.
Redline_Me is offline   Reply With Quote
Old 02-07-2010, 09:34 AM   #3 (permalink)
pedron
Guest
Posts: n/a
View pedron's Photo Gallery
welcome to TN. My guess is your ignitor has too much rust proofing on it.
Old 02-07-2010, 10:05 AM   #4 (permalink)
View ASHR's Photo Gallery
Smile
Hi there ,
I guess too it came up for me after a rust proofing , does it mean a full ignitor change or any recomendations
thanks and regards
ASHR is offline   Reply With Quote
Old 02-18-2010, 02:54 AM   #5 (permalink)
THANKS , Rust proofing was the root cause.My Air filter replaced and Spark plugs cleaned Now car runs smooth.
......Thats is for Crown rust in Mississauga ....... ......
Old 02-18-2010, 08:59 PM   #6 (permalink)
View MyFirstCamry's Photo Gallery
Gen6
Hi guys,
Just wondering how the rustproofing could cause this to happen? I am not sure what you mean by "ignitor" having too much rustproofing on it. By that, do you mean the coil packs??? Reason I ask is that I get my 07 Camry Rust Checked every year. Up here they throw down more rock salt than you can shake a stick at.
Also, how would rust proofing get onto the sparkplugs??
MyFirstCamry is offline   Reply With Quote
