Tire pressure monitor "reset"
I'm not excited about changing oil when it's below freezing, so I took my car out to get oil changed this weekend. I've seen a few people on here talk about using Walmart, so I decided to try them.
Quick summary: I won't get going there again. No one speaks English as a primary language, and they took over 1.5 hours to do an oil change and tire rotation.
But on to my primary issue. They charge $2.50/tire for tire rotation - $10 total. Which is fine; it's $10 cheaper than Jiffy Lube. But when they rang me up I found a $5/tire "TPM reset" charge. They say the tire pressure monitor has to be reset when tires are rotated. I attempted to explain that that made no logical sense: as far as I know, the device in the tire is simply broadcasting a unique ID programmed into the sensor ( so that the system only listens to your tires and not the tires on the Camry next to you) and a tire pressure.
I've rotated my own tires; I also had Jiffy Lube do it a couple of times when my wife finds coupons and I'm feeling lazy. I've never heard of this. I have found that there is some kind of reset button in the glove box, but I haven't found any docs saying this needs to be pressed after a rotation.
This $20 charge seems like B.S. to me. Am I wrong?
