INFO: What are coilovers? & Basic Gen5 Coilover Offerings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2010, 03:42 PM   #1 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Gen5 INFO: What are coilovers? & Basic Gen5 Coilover Offerings
I've been doing some looking into possibly getting a gen5.5 SE this summer, and so I've been doing some suspension research. I know this isn't a complete list of everything suspension wise for the gen5, but I thought i'd post up some info about the coilovers for those that are interested in what they are and what is available. I've listed as much useful info as I could gather up. Just remember that other spring rates may be available. Questions about such details can be directed at the manufacturers. I even included email addys and phone numbers. Enjoy!
-Lynch
Here's a 4-part video playlist I compiled that explains what coilovers are and how they're adjusted. Please note that skunk2 DOESN'T offer coilovers for the gen5/5.5 camry! This is just for your knowledge.
Part 1:
Part 2:
Part 3:
Part 4:
Available Coilovers for the Gen5/5.5 (2002-2006):
KSport Kontrol Pro Coilovers http://www.raceinspired.com/p-15125-...2002-2006.aspx
Features:
1. 36 levels of adjustable damping
2. Made from high quality 6061 aluminum with T6 for increased hardness
3. Compression/Rebound adjustable
4. Adjustable spring perch for height adjustment
5. Adjustable body allowing maximum suspension travel
6. Pillowball top mount with adjustable camber (not available for some models)
7. Monotube high pressure design reduces oil leakage
8. Electroplated body for protection from corrosion and rust
9. One year limited warranty
Rates (F/R, kg/mm): 9/5
Part #: KSP-CTY04-KP (15125)
Approx. Total Price: $950 USD
Phone: 480-829-8100
E-mail: info@ksportusa.com
Ksport GT Pro Coilovers http://www.raceinspired.com/p-15264-...2002-2006.aspx
Features: All Kontrol Pro Features, PLUS:
1. Inverted steel shock absorber for durability
2. Lower center of gravity and higher chassis rigidity
3. Designed to reduce friction for cooler shock oil temperature
4. Inverted design like vehicles in WRC and all JGTC cars
Rates (F/R, kg/mm): 9/4
Part #: KSP-CTY04-GT (15264)
Approx. Total Price: $1300 USD
Phone: 480-829-8100
BC Racing coilovers (Type BR) http://www.eracingzone.com/BC-Racing...g-p-44249.html
Features:
1. Mono-tube shock design
2. 30 levels of damping force
3. Pillowball mounts Included on most application (some application comes with camber plates
4. Adjustable rear camber plates available
5. Separate Full length height adjustable
6. Inverted and Non-Inverted setups
7. One year warranty
8. Rebuildable
9. Coilovers use 46mm pistons and 53mm shock housings.
10. Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life.
11. Valve stacks use a patented deflective system to provide more precise control.
12. Patented concave lower locking ring, to prevent unseating
13. Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
14. T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
15. Iron lower brackets on MacPherson struts to ensure rigidity
16. Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
17. High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
18. 2 step coating process utilizing nickel and chromium plating to prevent corrosion
Rates (F/R, kg/mm): 6/4
Part #: C-10
Approx. Total Price: $1000 USD
Phone: 1-407-637-2941
E-mail: sales@bcracing-na.com
Note: Type BR and Type RAM have no rear camber adjustment or rear pillow ball mounts. Type RAM coilovers at the same spring rates also seem to be avilible per BC Racing's site. Type RAM are inverted monotubes and have a MSRP of $1450 USD. http://www.bcracing-na.com/downloads...ATION_LIST.pdf
D2 Racing Sports RS Coilovers
http://www.hopupracing.com/d2rasprscosy53.html
Features:
1. "The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts*. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US."
2. ??? CP F/R: F
3. ??? TM F/R: R
4. Monotube High Pressure Design reduces oil leakage (Front and Rears Inverted)
5. 36-way adjustable dampening
6. Made from high quality 6061 Aluminum with T6 for increased hardness
7. Compression/Rebound adjustable
8. Adjustable spring perch for height adjustment
9. Adjustable body allowing maximum suspension travel
10. Pillow Ball Top Mount w/ adjustable camber (not available for some models)
11. Electroplated body for protection from corrosion and rust
12. One Year Limited Warranty
Rates (F/R, kg/mm): ?/?
Part #: D2-T04
Approx. Total Price: $900 USD
Phone: 919-544-4171
E-mail: info@d2racing.com
Good thread for more info: need help with coilovers
'07 Honda Ruckus Big Bore
The Following User Says Thank You to LynchburgCSI For This Useful Post:
Punks_Not_Dead5 (02-08-2010)
Old 02-08-2010, 04:55 PM   #2 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1076358
iTrader Score: 7 reviews
Thanks man. If you add more, i'll probably end up sticking it up top to make it easier on people searching.
Gen 5 5.5 Ftmfw!
2002 Camry SE V6 "Snow White"
Old 02-08-2010, 05:46 PM   #3 (permalink)
scamry's Avatar
Gameroom cash: $193525
View scamry's Photo Gallery
thanks for deleting the other posts punks..haha
is it cool if we add reviews and what not here??
I miss the old days of TN.
scamry is online now   Reply With Quote
Old 02-08-2010, 06:28 PM   #4 (permalink)
Just didn't want it to be a which Gen is better thread you know? lol
Yea add reviews on coils, and springs. Since a lot of people have been asking lately this thread is a good idea.
Old 02-09-2010, 03:42 PM   #5 (permalink)
Freakin Scooters
^ exactly. Collect more info here and i'll add it to the first post.
Old 02-09-2010, 05:46 PM   #6 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
View ebumdude's Photo Gallery
lol. Punks got me again.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
